Hi, I have a problem.esp 32 TTGO can't connecting MQTT
#include <WiFi.h>
#include <PubSubClient.h>
//#include "UbidotsESPMQTT.h"
//Libraries for LoRa
#include <SPI.h>
#include <LoRa.h>
//Libraries for OLED Display
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define WIFISSID "ZyXEL_KEENETIC_620" // Put your WifiSSID here
#define PASSWORD "09101939" // Put your wifi password here
#define TOKEN "BBFF-LamC2X9MfgFypdT0UohUiTCoT1iGHh" // Put your Ubidots' TOKEN
#define MQTT_CLIENT_NAME "ESP32_Health_Station" // MQTT client Name, please enter your own 8-12 alphanumeric character ASCII string;
#define VARIABLE_LABEL1 "Temperature" // Assing the variable label
#define DEVICE_LABEL "esp32"
#define SERVER "things.ubidots.com"
#define TOPIC "/v1.6/devices/esp32"
//define the pins used by the LoRa transceiver module
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14
#define DIO0 26
//433E6 for Asia
//866E6 for Europe
//915E6 for North America
#define BAND 433E6
//OLED pins
#define OLED_SDA 21
#define OLED_SCL 22
#define OLED_RST 16
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Replace with your network credentials
// Variables to save date and time
// Initialize variables to get and save LoRa data
int rssi;
String loRaMessage;
String temperature;
String readingID;
char mqttBroker[]  = "industrial.api.ubidots.com";
char payload[100];
char topic1[150];
// Space to store values to send
char str_Temperature[10];
WiFiClient ubidots;
PubSubClient client(ubidots);
void callback(char* topic, byte* payload, unsigned int length) {
  char p[length + 1];
  memcpy(p, payload, length);
  p[length] = NULL;
  Serial.write(payload, length);
  Serial.println(topic1);
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.println("Attempting MQTT connection...");
    // Attemp to connect
    if (client.connect(MQTT_CLIENT_NAME, TOKEN, "")) {
      Serial.println("Connected");
      Serial.print("Failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 2 seconds");
      // Wait 2 seconds before retrying
      delay(2000);
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RST);
// Replaces placeholder with DHT values
String processor(const String& var){
  //Serial.println(var);
  if(var == "TEMPERATURE"){
    return temperature;
  else if (var == "RRSI"){
    return String(rssi);
  return String();
//------------------Initialize OLED Module-------------------------------------------//
void initOLED(){
  //reset OLED display via software
  pinMode(OLED_RST, OUTPUT);
  digitalWrite(OLED_RST, LOW);
  delay(20);
  digitalWrite(OLED_RST, HIGH);
  //initialize OLED
  Wire.begin(OLED_SDA, OLED_SCL);
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3c, false, false)) { // Address 0x3C for 128x32
    Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
  display.clearDisplay();
  display.setTextColor(WHITE);
  display.setTextSize(1);
  display.setCursor(0,0);
  display.print("LORA RECEIVER");
//----------------------Initialize LoRa Module-----------------------------------------//
void initLoRA(){
  int counter;
  //SPI LoRa pins
  SPI.begin(SCK, MISO, MOSI, SS);
  //setup LoRa transceiver module
  LoRa.setPins(SS, RST, DIO0);
  while (!LoRa.begin(BAND) && counter < 10) {
    Serial.print(".");
    counter++;
  if (counter == 10) {
    // Increment readingID on every new reading
    Serial.println("Starting LoRa failed!");
  Serial.println("LoRa Initialization OK!");
  display.setCursor(0,10);
  display.print("LoRa Initializing OK!");
  display.display();
  delay(2000);
//----------------------Connect to WiFi Function-----------------------------------------//
//-----------------Read LoRa packet and get the sensor readings-----------------------//
void getLoRaData() {
  Serial.print("Lora packet received: ");
  // Read packet
  while (LoRa.available()) {
    String LoRaData = LoRa.readString();
    // LoRaData format: readingID/temperature&soilMoisture#batterylevel
    // String example: 1/27.43&654#95.34
    Serial.print(LoRaData);
    // Get readingID, temperature and soil moisture
    int pos1 = LoRaData.indexOf('/');
    int pos2 = LoRaData.indexOf('&');
    int pos3 = LoRaData.indexOf('#');
    readingID = LoRaData.substring(0, pos1);
    temperature = LoRaData.substring(pos1 +1, pos2);
  // Get RSSI
  rssi = LoRa.packetRssi();
  Serial.print(" with RSSI ");
  Serial.println(rssi);
//-----------------------Function to get date and time from NTPClient------------------//
//-------------------------Display Readings on OLED-------------------------------------//
void displayReadings()
  display.println("LoRa RECEIVER 1- Pune");
  display.setCursor(0,20);
  display.print("TEMPERATURE");
  display.setCursor(70,20);
  display.print(":");
  display.setCursor(80,20);
  display.print(temperature);
  display.drawCircle(116,20,1, WHITE);
  display.setCursor(121,20);
  display.print("C");
  display.display();
void setup(){
//  serial.begin(115200);
 WiFi.begin(WIFISSID, PASSWORD);
  Serial.print("Waiting for WiFi Connection ..............");
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi Connected");
  Serial.println("IP address: ");
  client.setServer(mqttBroker, 1883);
  client.setCallback(callback);
  // Initialize Serial Monitor
  initOLED();
  initLoRA();
if (!client.connected()) {
    reconnect();
sprintf(topic1, "%s%s", "/v1.6/devices/", DEVICE_LABEL);
  sprintf(payload, "%s", ""); // Cleans the payload
  sprintf(payload, "{\"%s\":", VARIABLE_LABEL1); // Adds the variable label
  /* 4 is minimum width, 2 is precision; float value is copied onto str_sensor*/
  //dtostrf(temperatur, 4, 2, str_Temperatur);
 // sprintf(payload, "%s {\"value\": %s}}", payload, str_Temperature); // Adds the value
  Serial.println("Publishing data to Ubidots Cloud");
  client.publish(topic1, payload);
  client.loop();
  // Check if there are LoRa packets available
  int packetSize = LoRa.parsePacket();
  if (packetSize) {
    getLoRaData();
    displayReadings();
Thanks for the answer please I have a lot of problems in this code I want to send the temperature value to ubidots please help me
#include <WiFi.h>
#include "freertos/FreeRTOS.h"
#include <SPI.h>
#include <LoRa.h>
#include <Wire.h>
#define DEVICE_LABEL "esp32"   // Assing the variable label
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14
#define DIO0 26
#define BAND 433E6
//OLED pins
#define OLED_SDA 21
#define OLED_SCL 22
#define OLED_RST 16
WiFiClient ubidots;
char payload[100];
char topic1[150];
int rssi;
String loRaMessage;
String temperature;
String readingID;
    return temperature;
  return String();
void initOLED(){
  delay(20);
  //initialize OLED
void initLoRA(){
  int counter;
  //SPI LoRa pins
    Serial.print(".");
    counter++;
  display.display();
  delay(2000);
  // Read packet
  // Get RSSI
  display.print(":");
  display.print("C");
  display.display();
void setup(){
    Serial.print(".");
  initOLED();
  initLoRA();
 void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( WIFISSID, PASSWORD );
    vTaskDelay( 4000 );
    if ( TryCount == 10 )
      ESP.restart();
 // WiFi.onEvent( WiFiEvent );
void connectToMQTT()
  MQTTclient.setKeepAlive( 90 ); // needs be made before connecting
  byte mac[5];
  WiFi.macAddress(mac);
  String clientID = String(mac[0]) + String(mac[4]) ; // use mac address to create clientID
  while ( !MQTTclient.connected() )
    // boolean connect(const char* id, const char* user, const char* pass, const char* willTopic, uint8_t willQos, boolean willRetain, const char* willMessage);
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password, NULL , 1, true, NULL );
    vTaskDelay( 250 );
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe( topicOK );
void MQTTkeepalive( void *pvParameters )
  sema_MQTT_KeepAlive   = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  // setting must be set before a mqtt connection is made
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
      MQTTclient.loop();
    else {
      log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
    vTaskDelay( 250 ); //task runs approx every 250 mS
  vTaskDelete ( NULL );
    reconnect();
  /* 4 is minimum width, 2 is precision; float value is copied onto str_Temperature*/
  client.loop();
  if (packetSize) {
    getLoRaData();
    displayReadings();
}نص منسَّق سابقًا
You see you use the word "client" to name your MQTT client object, right?
You might notice I use the word "MQTTclient" as my MQTT pubsubclient object.
If you were to change the name of "MQTTclient", which is how I named the object to 'client' which is what you named your object you may find a solution to this one issue.
Actually, the code I posted is to complicated don't use it. sorry for posting. I've deleted it. Sorry to have led you down the wrong path.
Good luck.
