hi i have a scketch for esp8266 and does not fit to my wemos d1-r2
i now for you is it a piece of cake
i post the sketch pleas tell me somthing
ESP8266 library
When you use with UNO board, uncomment the follow line in uartWIFI.h.
#define UNO
When you use with MEGA board, uncomment the follow line in uartWIFI.h.
#define MEGA
Connection:
When you use it with UNO board, the connection should be like these:
ESP8266_TX->(your softserial receive pin)
ESP8266_RX->1K resistor->(your softserial transmit pin)
ESP8266_CH_PD->3.3V
ESP8266_VCC->3.3V
ESP8266_GND->GND
When you use it with MEGA board, the connection should be like these:
ESP8266_TX->RX1(D19)
ESP8266_RX->TX1(D18)
ESP8266_CH_PD->3.3V
ESP8266_VCC->3.3V
ESP8266_GND->GND
When you want to output the debug information, please use DebugSerial. For example,
DebugSerial.println("hello");
Note: The size of message from ESP8266 is too big for arduino sometimes, so the library can't receive the whole buffer because
the size of the hardware serial buffer which is defined in HardwareSerial.h is too small.
Open the file from \arduino\hardware\arduino\avr\cores\arduino\HardwareSerial.h.
See the follow line in the HardwareSerial.h file.
#define SERIAL_BUFFER_SIZE 64
The default size of the buffer is 64. Change it into a bigger number, like 256 or more.
#define SSID "mats"
#define PASSWORD "6942589705"
#include "uartWIFIUNO.h"
#include <SoftwareSerial.h>
WIFIUNO wifi;
extern int chlID; //client id(0-4)
int sprinkler = 5;
int LED2 = 6;
extern int chlID;
pinMode(sprinkler,OUTPUT);
digitalWrite(sprinkler,HIGH); //pullup to turn off.
pinMode(LED2,OUTPUT);
digitalWrite(LED2,LOW);
wifi.begin();
bool b = wifi.Initialize(STA, SSID, PASSWORD);
if(!b)
DebugSerial.println("Init error");
delay(8000); //make sure the module can have enough time to get an IP address
String ipstring = wifi.showIP();
DebugSerial.println(ipstring); //show the ip address of module
delay(2000);
wifi.confMux(1);
delay(100);
if(wifi.confServer(1,8080))
DebugSerial.println("Server is set up");
char buf[100];
int iLen = wifi.ReceiveMessage(buf);
if(iLen > 0)
DebugSerial.println(buf);
if (strstr(buf, "HELLO") != NULL)
digitalWrite(sprinkler,LOW);
DebugSerial.println("GOT HELLO");
if(wifi.Send(chlID,"HELLO from Arduino!\r\n"))
DebugSerial.println("Message sent okay.");
if (strstr(buf, "CH0ON") != NULL)
DebugSerial.println("CH0ON");
wifi.Send(chlID,"Sprinkler ON\r\n");
if (strstr(buf, "CH0OFF") != NULL)
DebugSerial.println("CH0OFF");
wifi.Send(chlID,"Sprinkler OFF\r\n");
if (strstr(buf, "CH1ON") != NULL)
digitalWrite(LED2,HIGH);
DebugSerial.println("CH1ON");
if (strstr(buf, "CH1OFF") != NULL)
DebugSerial.println("CH1OFF");
the erros is
C:\Users\mats\Desktop\my project\SprinklerControl-master\ESP8266_RelayBoard\ESP8266_RelayBoard.ino:96:25: fatal error: uartWIFIUNO.h: No such file or directory
compilation terminated.
exit status 1
Error compiling for board WeMos D1 R2 & mini.
I fail to see how this message relates to whether or not the sketch fits your wemos-which-isn't-really-an-Arduino.
PaulS:
how about now ?
ESP8266 library
#define UNO
#define MEGA
Connection:
ESP8266_CH_PD->3.3V
ESP8266_VCC->3.3V
ESP8266_GND->GND
ESP8266_CH_PD->3.3V
ESP8266_VCC->3.3V
ESP8266_GND->GND
#define SSID "yourssid"
#define PASSWORD "yourpassword"
WIFIUNO wifi;
int sprinkler = 5;
int LED2 = 6;
extern int chlID;
wifi.begin();
if(!b)
delay(2000);
wifi.confMux(1);
delay(100);
char buf[100];
if(iLen > 0)
Maybe have a look at this article:
PaulS:
sorry i misunderstand what you said
Dan95:
http://www.instructables.com/id/Programming-the-WeMos-Using-Arduino-SoftwareIDE/
than you dan95 for your interest bus this is for beginners with wemos
what I want is to change the code for you can use it to my wemos
If you have a size 10 boot and a size 14 foot, does it matter whether it is snowing?
You claim that the code won't fit on your device, for some definition of fit, when the code won't even compile. When the code won't compile, you do NOT get any measure of size, so you have nothing on which to base a claim that "it doesn't fit".
PaulS:
you are telling me that it used the wrong term to say my problem?
sorry for my English
the codes work for my wemos... better now ?
The problem is that the file that you try to include could not be found by the compiler. Looking at the way you have included it (using double quotes), it is more than likely supposed to be in the sketch directory. Do you have the file uartWIFIUNO.h in there? Do you have it anywhere on your computer?
And when posting code, please use code tags so it looks like your code here
sterretje:
sterretje you are a god thanx you very much you unblock me
