#include <AFMotor.h>
#include "AnimateBilly.h"
#define NUM_MOTORS 2
AF_DCMotor head(1, MOTOR12_1KHZ); // create motor #2, 64KHz pwm
AF_DCMotor mouth(2, MOTOR12_1KHZ);
int sensorPin = A0; // select the input pin for the audio signal
int ledPin = 13;
void runMotorOnOff(AF_DCMotor motor, int aniDelay = 500) {
motor.run(FORWARD);
delay(aniDelay);
motor.run(BACKWARD);
delay(5);
motor.run(RELEASE);
delay(aniDelay);
void runTwoMotorsOnOff(AF_DCMotor motor1, AF_DCMotor motor2, int aniDelay = 500) {
motor1.run(FORWARD);
motor2.run(FORWARD);
delay(aniDelay);
motor1.run(BACKWARD);
motor2.run(BACKWARD);
delay(5);
motor1.run(RELEASE);
motor2.run(RELEASE);
delay(aniDelay);
bool randomDecisionToTurnOn(int oddsOn) {
int score = random(1, 100);
return score < oddsOn;
void releaseMotor(AF_DCMotor motor) {
delay(15);
motor.run(RELEASE);
void dance(int duration, int times = 2) {
int elapsedTime = 0;
int iterDuration = duration / times;
for (int i = 0; i < times; i++) {
if (randomDecisionToTurnOn(60))
void talk(int duration, int wordCount) {
int iterDuration = duration / wordCount;
head.run(FORWARD);
for (int i = 0; i < wordCount; i++) {
runMotorOnOff(mouth, iterDuration);
int sampleSensor(int pin, int samples = 20, int duration = 250) {
float sensorValue = 0;
int iterDelay = duration / samples;
for (int i = 0; i < samples; i++) {
sensorValue += analogRead(pin);
delay(iterDelay);
digitalWrite(ledPin, LOW);
return (int)(sensorValue / samples);
AF_DCMotor motors[NUM_MOTORS] = {head, mouth};
void setupFishMotors() {
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("Motor test!");
for (int i = 0; i < NUM_MOTORS; i++) {
motors[i].setSpeed(255);
int sampleAverages(int pin, int samples = 3, int duration = 100) {
int avgValue = 0;
avgValue += sampleSensor(pin, samples, iterDelay);
delay(iterDelay);
void billySleep() {
head.run(RELEASE);
tail.run(RELEASE);
void moveBilly(int movementCount, int duration) {
if (movementCount > 3) {
billySleep();
dance(duration, random(1, 4));
return (int)(avgValue / samples);
setupFishMotors();
// declare the ledPin as an OUTPUT:
pinMode(ledPin, OUTPUT);
Serial.begin(9600); // open the serial port at 9600 bps:
int stillPlaying = 0;
int aniDuration = 500;
int previousValue = 0;
int quietThreshold = 2;
// read the value from the sensor:
int sensorValue = sampleSensor(sensorPin);
float smoothedSensorValue = (sensorValue + previousValue) / 2 ;
if (smoothedSensorValue > quietThreshold) {
digitalWrite(ledPin, HIGH);
stillPlaying = min(stillPlaying++, 4);
moveBilly(stillPlaying, aniDuration);
} else if (stillPlaying == 0) {
billySleep();
stillPlaying = 0;
talk(duration, random(2, 6));
stillPlaying--;
previousVPreformatted textalue = sensorValue;
my error messages were:
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
C:\Users\johns\OneDrive\Documents\Arduino\trout\trout.ino:4:0: warning: "NUM_MOTORS" redefined
In file included from C:\Users\johns\OneDrive\Documents\Arduino\trout\trout.ino:2:0:
C:\Users\johns\OneDrive\Documents\Arduino\libraries\billy/AnimateBilly.h:3:0: note: this is the location of the previous definition
#define NUM_MOTORS 3
trout:5:16: error: redefinition of 'AF_DCMotor head'
C:\Users\johns\OneDrive\Documents\Arduino\libraries\billy/AnimateBilly.h:4:12: note: 'AF_DCMotor head' previously declared here
trout:6:17: error: redefinition of 'AF_DCMotor mouth'
C:\Users\johns\OneDrive\Documents\Arduino\libraries\billy/AnimateBilly.h:5:12: note: 'AF_DCMotor mouth' previously declared here
C:\Users\johns\OneDrive\Documents\Arduino\trout\trout.ino: In function 'void runMotorOnOff(AF_DCMotor, int)':
trout:11:6: error: redefinition of 'void runMotorOnOff(AF_DCMotor, int)'
C:\Users\johns\OneDrive\Documents\Arduino\libraries\billy/AnimateBilly.h:9:6: note: 'void runMotorOnOff(AF_DCMotor, int)' previously defined here
void runMotorOnOff(AF_DCMotor motor, int aniDelay = 500){
C:\Users\johns\OneDrive\Documents\Arduino\trout\trout.ino: In function 'void runTwoMotorsOnOff(AF_DCMotor, AF_DCMotor, int)':
trout:20:6: error: redefinition of 'void runTwoMotorsOnOff(AF_DCMotor, AF_DCMotor, int)'
C:\Users\johns\OneDrive\Documents\Arduino\libraries\billy/AnimateBilly.h:18:6: note: 'void runTwoMotorsOnOff(AF_DCMotor, AF_DCMotor, int)' previously defined here
void runTwoMotorsOnOff(AF_DCMotor motor1, AF_DCMotor motor2, int aniDelay = 500){
C:\Users\johns\OneDrive\Documents\Arduino\trout\trout.ino: In function 'bool randomDecisionToTurnOn(int)':
trout:32:6: error: redefinition of 'bool randomDecisionToTurnOn(int)'
C:\Users\johns\OneDrive\Documents\Arduino\libraries\billy/AnimateBilly.h:30:6: note: 'bool randomDecisionToTurnOn(int)' previously defined here
C:\Users\johns\OneDrive\Documents\Arduino\trout\trout.ino: In function 'void releaseMotor(AF_DCMotor)':
trout:37:6: error: redefinition of 'void releaseMotor(AF_DCMotor)'
C:\Users\johns\OneDrive\Documents\Arduino\libraries\billy/AnimateBilly.h:35:6: note: 'void releaseMotor(AF_DCMotor)' previously defined here
C:\Users\johns\OneDrive\Documents\Arduino\trout\trout.ino: In function 'void dance(int, int)':
trout:44:6: error: redefinition of 'void dance(int, int)'
C:\Users\johns\OneDrive\Documents\Arduino\libraries\billy/AnimateBilly.h:47:6: note: 'void dance(int, int)' previously defined here
void dance(int duration, int times = 1){
trout:49:5: error: expected primary-expression before '}' token
C:\Users\johns\OneDrive\Documents\Arduino\trout\trout.ino: At global scope:
trout:51:1: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences.
type or paste code here
