Hi, im new here, and when I tried an Arduino Code which is funtional, the next error appears:
"int LiquidCrystal::init()" is private within this context
In file included from C:\Users\PCW10\AppData\Local\Temp\Rar$DIa1900.47720\Sketch-Ardu-OHM\Sketch-Ardu-OHM.ino:2:0:
C:\Users\PCW10\Documents\Arduino\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h:154:9: note: declared private here
int init();
exit status 1
'int LiquidCrystal_I2C::init()' is private within this context.
I'm using this library: LiquidCrystal - Arduino Reference
And this is the entery code:
#include <Wire.h>
/*________________________________
|Original Sketch By Aaron Kable|
Monitoreo de PC mediante: Arduino + Open hardware monitor, Con LCD 20x4
Sketch modificado Por "Fenrir93" 22/11/2016
LiquidCrystal_I2C lcd(0x27,20,4); // Declaramos nuestra LCD
/*Creamos Carateres especiales para nuestro monitor*/
byte line5[8] =
{// full
B11111,
B00000,
B11111,
B11111,
B11111,
B11111,
B00000,
B11111
byte line4[8] =
{// 80%
B11111,
B00000,
B11110,
B11110,
B11110,
B11110,
B00000,
B11111
byte line3[8] =
{// 60%
B11111,
B00000,
B11100,
B11100,
B11100,
B11100,
B00000,
B11111
byte line2[8] =
{// 40%
B11111,
B00000,
B11000,
B11000,
B11000,
B11000,
B00000,
B11111
byte line1[8] =
{ // 20%
B11111,
B00000,
B10000,
B10000,
B10000,
B10000,
B00000,
B11111
byte line0[8] =
{ // empty
B11111,
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B11111
byte loadchar[8] =
{ // Caracter % para la grafica
B11111,
B00000,
B10010,
B00100,
B01000,
B10010,
B00000,
B11111
byte tempchar[8] =
{ // termometro
B00100,
B01010,
B01010,
B01010,
B01010,
B10001,
B10001,
B01110
String inputString = ""; //String de entrada compuesto
boolean NewData = false;
//Declaramos strings de datos fraccionando el string compuesto
String CPUT = ""; //Temperatura de CPU
String GPUT = ""; // Temperatura de GPU
String GPUFC = ""; // % de control del ventilador de la GPU
String MotherT= ""; // Temperatura de la MotherBoard
String HDDT = ""; // Temperatura del disco duro
//Variables para conversiones matematicas, a partir de inputString
int Cload= 0; // Variable de la carga actual del Procesador
int Gload= 0; //variable de la carga actual de la GPU
int CFanSpeed= 0; //Variable RPM Ventilador de CPU (revisar conector en motherboard)
int SpeedMap= 0; // Variable de conversion de RPM a %(0 a 100);
int RLoad= 0; // % de Uso de la ram total 0 a 100
int Aviso1= 0; //Variable extra para proporcionar un aviso visual o auditivo, cuando la temperatura llegue a cierto Valor
int Aviso2= 0; //Variable extra para proporcionar un aviso visual o auditivo, cuando la temperatura llegue a cierto Valor
// setup LCD
lcd.init();
//lcd.backlight(); //Si borramos los "//" del inicio la retroiluminacion del lcd se activa al encender la PC
// Reservamos 400 bits para inputString:
inputString.reserve(400);
lcd.backlight();
lcd.setCursor(2,0);
lcd.print("Monitor de temp.");
lcd.setCursor(3,1);
lcd.print("Arduino & OHM");
lcd.setCursor(4,2);
lcd.print("By Fenrir_93");
lcd.setCursor(7,3);
lcd.print("Para T!");
delay(4000);
lcd.clear();
lcd.noBacklight();
//Descripcion de los datos que se imprimiran en la LCD
lcd.backlight();
lcd.setCursor(1,0);
lcd.print("CPU-Temp-Fan-Load");
lcd.setCursor(1,1);
lcd.print("GPU-Temp-Fan-Load");
lcd.setCursor(6,2);
lcd.print("RAM Load");
lcd.setCursor(4,3);
lcd.print("Mother & HDD");
delay(4000);
lcd.clear();
lcd.noBacklight();
/*Declaramos pines 12 y 13 como salida*/
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
//Creamos los carater especiales
lcd.createChar(6, line0); // No se puede usar"0"
lcd.createChar(1, line1);
lcd.createChar(2, line2);
lcd.createChar(3, line3);
lcd.createChar(4, line4);
lcd.createChar(5, line5);
lcd.createChar(7, loadchar);
lcd.createChar(8, tempchar);
int iHome = 1;
int diff = 1;
int count = 5;
int dely = 0;
//Dibujamos la graficas con los caracteres especiales
void graph(int load, int width){
float weight = 100/width;
float full_cells_f = load/weight;
int full_cells = full_cells_f;
int i = 0;
while(i<full_cells){
lcd.write(5);
i++;
// escalamos las celdas
int wt = weight;
int test = (load-(wt*full_cells))/2;
if (test == 0){
test = 6;
if (load < 100){
lcd.write(test);
i++;
while(i<width){
lcd.write(6);
i++;
if (NewData) {
//Limpiamos la LCD al empezar
//Emepzamos a distribuir nuestros datos en el LCD (Nota: esta distribucion es para una lcd 20x4)
lcd.backlight(); //encendemos la retroiluminacion del LCD
lcd.clear();
lcd.setCursor(0, 0);
lcd.write(8);
lcd.print(CPUT);
lcd.print((char)223);
lcd.setCursor(5,0);
lcd.print(SpeedMap);
lcd.setCursor(0, 1);
lcd.write(8);
lcd.print(GPUT);
lcd.setCursor(5,1);
lcd.print(GPUFC);
lcd.setCursor(9,1);
lcd.write (7);
graph(Gload,10);
lcd.setCursor(9, 0);
lcd.write(7);
graph(Cload,10);
lcd.setCursor(1,2);
lcd.print("RAM");
lcd.setCursor(9,2);
lcd.write(7);
graph(RLoad,10);
lcd.setCursor(0,3);
lcd.print("Mother:");
lcd.write(8);
lcd.print(MotherT);
lcd.setCursor(12,3);
lcd.print("HDD:");
lcd.write(8);
lcd.print(HDDT);
/*Calculo de ventilador del CPU, de RPM a %*/
SpeedMap= map(CFanSpeed,0,3080,0,100);// En este caso el numero 3080 indica las RPM maxima del ventilador.
/*Valor para activar el led del pin13 cuando la temperatura llegue o supere cierto valor*/
if(Aviso1 >= 50){
digitalWrite(13,HIGH);
} //Se enciende al llegar a los 50 o mas grados en este ejemplo
else{
digitalWrite(13,LOW);
} //Se apaga si menor a dicha temperatura
if(Aviso2 >= 50){
digitalWrite(12,HIGH);
else{
digitalWrite(12,LOW);
/*Borramos el Input*/
inputString = "";
NewData = false;
int b[8];// b #0
void serialEvent() {
b[0] = 0;
while (Serial.available()) {
// Obtener el nuevo byte:
char inChar = (char)Serial.read();
// Agregarlo a inputString:
inputString += inChar;
// Si el carácter entrante coincide habilitamos:
if (inChar == '\n') {
//Establecemos los separadores ","
b[1] = inputString.indexOf(',');
b[2] = inputString.indexOf(',', b[1]+1);
b[3] = inputString.indexOf(',', b[2]+1);
b[4] = inputString.indexOf(',', b[3]+1);
b[5] = inputString.indexOf(',', b[4]+1);
b[6] = inputString.indexOf(',', b[5]+1);
b[7] = inputString.indexOf(',', b[6]+1);
b[8] = inputString.indexOf(',', b[7]+1);
b[9] = inputString.indexOf(',', b[8]+1);
b[10] = inputString.indexOf(',', b[9]+1);
//Seleccionamos los strings de entrada para poder imprimirlos en la lcd
CPUT = inputString.substring(b[0],b[1]);
GPUT = inputString.substring(b[3]+1,b[4]);
GPUFC = inputString.substring(b[5]+1,b[6]);
MotherT = inputString.substring(b[7]+1,b[8]);
HDDT = inputString.substring(b[8]+1,b[9]);
//Declaramos strings para conversion a "int"
String RPM = inputString.substring(b[2]+1,b[3]);
String loadHold = inputString.substring(b[1]+1,b[2]);
String loadHold2 = inputString.substring(b[4]+1,b[5]);
String RL = inputString.substring(b[6]+1,b[7]);
//Convertimos Los string a "int" para crear avriables para la funcion de la grafica de Load
Cload = loadHold.toInt();
Gload = loadHold2.toInt();
CFanSpeed = RPM.toInt();
RLoad = RL.toInt();
Aviso1 = CPUT.toInt();
Aviso2 = CPUT.toInt();
NewData = true;
I wish somebody helps me.
Sorry for my English level
