Hello I'm trying to program the atmega328 with avrdude using arduino duemilanove board with the following command:
avrdude -v -v -v -v -v -v -c avrispmkII -p ATMEGA328P -P COM4 -b 115200 -C "C:\Program Files (x86)\Arduino\hardware\tools\avr\etc\avrdude.conf" -U flash:w:battery.hex
and this is the following output:
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr\etc\avrdude.conf"
Using Port : COM4
Using Programmer : avrispmkII
Overriding Baud Rate : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: ser_recv(): programmer is not responding
avrdude: stk500v2_ReceiveMessage(): timeout
it seems that's starting to send the code, I even see the leds RX Blink really fast, but then it stops....
can you help me program this hex file into my arduino?
Thank you very much.
PS: I'm doing that to program in pure C as shown here. I can program the arduino normally through the arduino's IDE, with the same configuration.
