Hi Guys,
i found to my disappointment that the leonardo has no pwm higher than 500hz or so. When i bought it, i thought that as it had pwm pins it would have some docs “libs” to handle them but as far as i search there is no one.
Guys my question is how can i make the pwm with the timers and register without screwing up the usb connection. i tried the code bellow. It compiles fine but after uploading, i lost usb connection and leonardo is not recognized. i pressed upload and just after compiling finished i pressed reset on board to get the new empty sketch uploaded and have the Leonardo recognized again:
Code:
#define TIMER4_RESOLUTION 1023UL
#define PLL_FREQ 48000000UL
unsigned long pwmPeriod = 0;
ISR(TIMER4_OVF_vect) {}
void enable_intr(){
TIMSK4 = _BV(TOIE4);
void disable_intr(){
TIMSK4 = 0;
void initialize(unsigned long freq) {
/* Init the internal PLL /
PLLFRQ = _BV(PDIV2);
PLLCSR = _BV(PLLE);
while(!(PLLCSR & _BV(PLOCK)));
PLLFRQ |= _BV(PLLTM0); / PCK 48MHz */
TCCR4A = (1<<PWM4A);
TCCR4E = (1<<ENHC4);
TCCR4D = (1<<WGM40); //set it to phase and frequency correct mode
TCCR4C = 0;
setPeriod(freq);
void setPwmDuty(unsigned int duty) {
unsigned long dutyCycle = pwmPeriod;
dutyCycle *= duty;
dutyCycle >>= 9;
TC4H = (dutyCycle) >> 8;
OCR4A = (dutyCycle) & 255;
void start() {
TCCR4A |= _BV(COM4A1);
void stop() {
TCCR4A &= ~(_BV(COM4A1));
void setPeriod(unsigned long freq) {
unsigned long cycles = PLL_FREQ / 2 / freq;
unsigned char clockSelectBits = 0;
if (cycles < TIMER4_RESOLUTION) {
clockSelectBits = _BV(CS40);
pwmPeriod = cycles;
} else
if (cycles < TIMER4_RESOLUTION * 2) {
clockSelectBits = _BV(CS41);
pwmPeriod = cycles / 2;
} else
if (cycles < TIMER4_RESOLUTION * 4) {
clockSelectBits = _BV(CS41) | _BV(CS40);
pwmPeriod = cycles / 4;
} else
if (cycles < TIMER4_RESOLUTION * 8) {
clockSelectBits = _BV(CS42);
pwmPeriod = cycles / 8;
} else
if (cycles < TIMER4_RESOLUTION * 16) {
clockSelectBits = _BV(CS42) | _BV(CS40);
pwmPeriod = cycles / 16;
} else
if (cycles < TIMER4_RESOLUTION * 32) {
clockSelectBits = _BV(CS42) | _BV(CS41);
pwmPeriod = cycles / 32;
} else
if (cycles < TIMER4_RESOLUTION * 64) {
clockSelectBits = _BV(CS42) | _BV(CS41) | _BV(CS40);
pwmPeriod = cycles / 64;
} else
if (cycles < TIMER4_RESOLUTION * 128) {
clockSelectBits = _BV(CS43);
pwmPeriod = cycles / 128;
} else
if (cycles < TIMER4_RESOLUTION * 256) {
clockSelectBits = _BV(CS43) | _BV(CS40);
pwmPeriod = cycles / 256;
} else
if (cycles < TIMER4_RESOLUTION * 512) {
clockSelectBits = _BV(CS43) | _BV(CS41);
pwmPeriod = cycles / 512;
} else
if (cycles < TIMER4_RESOLUTION * 1024) {
clockSelectBits = _BV(CS43) | _BV(CS41) | _BV(CS40);
pwmPeriod = cycles / 1024;
} else
if (cycles < TIMER4_RESOLUTION * 2048) {
clockSelectBits = _BV(CS43) | _BV(CS42);
pwmPeriod = cycles / 2048;
} else
if (cycles < TIMER4_RESOLUTION * 4096) {
clockSelectBits = _BV(CS43) | _BV(CS42) | _BV(CS40);
pwmPeriod = cycles / 4096;
} else
if (cycles < TIMER4_RESOLUTION * 8192) {
clockSelectBits = _BV(CS43) | _BV(CS42) | _BV(CS41);
pwmPeriod = cycles / 8192;
} else
if (cycles < TIMER4_RESOLUTION * 16384) { clockSelectBits = _BV(CS43) | _BV(CS42) | _BV(CS41) | _BV(CS40); pwmPeriod = cycles / 16384; } /*else clockSelectBits = _BV(CS43) | _BV(CS42) | _BV(CS41) | _BV(CS40); pwmPeriod = TIMER4_RESOLUTION - 1; */ TCCR4B = clockSelectBits; TC4H = pwmPeriod >> 8;
OCR4C = pwmPeriod;
pinMode(13, OUTPUT);
digitalWrite(13,LOW);
initialize(123456); // Frequency to generate in Hz
setPwmDuty(512); // Duty cycle 0-1024, 1024 is 100%, 512 is 50%
start();
void loop(){
any help is appreciated. i just started with Arduino so be gentle with me smiley-wink.
Timi
