Hi need to send values for firebase Realtime database... I'm using esp32
Hello, can someone modify this code in such a way that the values will move to the real-time database of Firebase? I need to access all 8 parameter values in the real-time database of google firebase.
// Get the Modbus master library at https://github.com/4-20ma/ModbusMaster
// Get the DHT sensor library at https://github.com/adafruit/DHT-sensor-library and https://github.com/adafruit/DHT-sensor-library
#include <ModbusMaster.h>
#include <HardwareSerial.h>
#include <DHT.h>
const int RO_PIN = 13;  // Receive (data in) pin
const int DI_PIN = 12;  // Transmit (data out) pin
const int RE_PIN = 22;
const int DE_PIN = 23;
const int DHT_PIN = 4;  // DHT data pin
const int DHT_TYPE = DHT11;  // DHT sensor type (DHT11, DHT21, DHT22)
HardwareSerial swSerial(2);  // Use Serial2 for communication
ModbusMaster node;
DHT dht(DHT_PIN, DHT_TYPE);
// Put the MAX485 into transmit mode
void preTransmission()
  digitalWrite(RE_PIN, HIGH);
  digitalWrite(DE_PIN, HIGH);
// Put the MAX485 into receive mode
void postTransmission()
  digitalWrite(RE_PIN, LOW);
  digitalWrite(DE_PIN, LOW);
  // Configure the MAX485 RE & DE control signals and enable receive mode
  pinMode(RE_PIN, OUTPUT);
  pinMode(DE_PIN, OUTPUT);
  // Modbus communication runs at 9600 baud
  swSerial.begin(9600, SERIAL_8N1, RO_PIN, DI_PIN);
  // Modbus slave ID of the NPK sensor is 2
  node.begin(2, swSerial);
  // Callbacks to allow us to set the RS485 Tx/Rx direction
  node.preTransmission(preTransmission);
  node.postTransmission(postTransmission);
  // Initialize the DHT sensor
  dht.begin();
  uint8_t result;
  // Remove any characters from the receive buffer
  // Ask for 7x 16-bit words starting at register address 0x0000
  result = node.readHoldingRegisters(0x0000, 7);
  if (result == node.ku8MBSuccess)
    Serial.println("Reply:");
    Serial.print("Temp: ");
    Serial.print(node.getResponseBuffer(0) / 10.0);
    Serial.println(" F");
    Serial.print("Moisture: ");
    Serial.print(node.getResponseBuffer(1) / 10.0);
    Serial.println("%");
    Serial.print("EC: ");
    Serial.print(node.getResponseBuffer(2));
    Serial.println(" uS/cm");
    Serial.print("pH: ");
    Serial.print(node.getResponseBuffer(3) / 100.0);
    Serial.println("");
    Serial.print("N: ");
    Serial.print(node.getResponseBuffer(4) * 10);
    Serial.println(" mg/kg");
    Serial.print("P: ");
    Serial.print(node.getResponseBuffer(5) * 10);
    Serial.print("K: ");
    Serial.print(node.getResponseBuffer(6) * 10);
    printModbusError(result);
  // Read temperature and humidity from DHT sensor
  float temperature = dht.readTemperature();
  float humidity = dht.readHumidity();
  // Check if any valid data was obtained from the DHT sensor
  if (!isnan(temperature) && !isnan(humidity)) {
    //Serial.print("DHT Temperature: ");
    //Serial.print(temperature);
    //Serial.println(" °C");
    Serial.print("DHT Humidity: ");
    Serial.print(humidity);
    Serial.println("Failed to read data from DHT sensor");
  delay(2000);
// Print out the error received from the Modbus library
void printModbusError(uint8_t errNum)
  switch (errNum)
    case node.ku8MBSuccess:
      Serial.println(F("Success"));
    case node.ku8MBIllegalFunction:
      Serial.println(F("Illegal Function Exception"));
    case node.ku8MBIllegalDataAddress:
      Serial.println(F("Illegal Data Address Exception"));
    case node.ku8MBIllegalDataValue:
      Serial.println(F("Illegal Data Value Exception"));
    case node.ku8MBSlaveDeviceFailure:
      Serial.println(F("Slave Device Failure"));
    case node.ku8MBInvalidSlaveID:
      Serial.println(F("Invalid Slave ID"));
    case node.ku8MBInvalidFunction:
      Serial.println(F("Invalid Function"));
    case node.ku8MBResponseTimedOut:
      Serial.println(F("Response Timed Out"));
    case node.ku8MBInvalidCRC:
      Serial.println(F("Invalid CRC"));
    default:
      Serial.println(F("Unknown Error"));
