Hi. question for "if" and "loop"
Hi i have problem. it can be easy for you guys.
here is the my code
pinMode(3, OUTPUT);
pinMode(7, OUTPUT);
pinMode(9, OUTPUT);
Serial.println("speed 0 to 255");
if(Serial.available()){
int speed=Serial.parseInt();
if(speed>=0 && speed<=255){
Serial.println("current speed:" + String(speed));
for(int i=0; i<=speed; i+=2){
digitalWrite(3,HIGH);
digitalWrite(7,LOW);
analogWrite(9,i);
Serial.println(i);
delay(100);
digitalWrite(7,HIGH);
analogWrite(9,i);
Serial.println(i);
delay(100);
It works well, but i made the program that
if i make input "60", "speed" will go from 0 to 60 and from 60 to 0 intinetly
but in my case,
after executing from 0 to 60 and from 60 to 0 once,
i should make input again
what i want is if i input "60", it would make loop without asking more
can you help me?
k_river:
after executing from 0 to 60 and from 60 to 0 once, i should make input again
can you help me?
It sounds like you want it to repeat 0 to 60 and 60 to 0 until you enter a different number. To do that, end the "if (Serial.available())" before the 0 to 60 and 60 to 0 part.
  pinMode(3, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(9, OUTPUT);
  static int speed = 0;  // 'static' means the variable will hold the value across calls to loop()
  // If there is any input, get the new value for 'speed'
  if (Serial.available()) {
    speed = Serial.parseInt();
    while (Serial.available())
      Serial.read(); // Flush any input after the number
  if (speed >= 0 && speed <= 255)
    Serial.print("Current speed: ");
    Serial.println(speed);
    for (int i = 0; i <= speed; i += 2)
      digitalWrite(3, HIGH);
      digitalWrite(7, LOW);
      analogWrite(9, i);
      Serial.println(i);
      delay(100);
      digitalWrite(7, HIGH);
      analogWrite(9, speed - i);  // 'i' is counting up but we want the speed to count down.
      Serial.println(speed - i);  // 'i' is counting up but we want the speed to count down.
      delay(100);
