HicTop
Hey Guys,
I am still an amateur at this so I do beg your pardon for it but I have a HicTop 3DP-12 3D Printer for which I have updated the hot end, and I am trying to update the firmware but I am getting the below error messages:
Arduino: 1.8.12 (Mac OS X), Board: "Arduino Mega or Mega 2560, ATmega1280"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/Ankur/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/Ankur/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/Ankur/Documents/Arduino/libraries -fqbn=arduino:avr:mega:cpu=atmega1280 -ide-version=10812 -build-path /var/folders/6f/mlpxpd056szfkr817zdxdh680000gn/T/arduino_build_883098 -warnings=none -build-cache /var/folders/6f/mlpxpd056szfkr817zdxdh680000gn/T/arduino_cache_697442 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/Users/Ankur/Library/Arduino15/packages/arduino/tools/avr-gcc/4.8.1-arduino5 -prefs=runtime.tools.avr-gcc-4.8.1-arduino5.path=/Users/Ankur/Library/Arduino15/packages/arduino/tools/avr-gcc/4.8.1-arduino5 -prefs=runtime.tools.avrdude.path=/Users/Ankur/Library/Arduino15/packages/arduino/tools/avrdude/6.0.1-arduino5 -prefs=runtime.tools.avrdude-6.0.1-arduino5.path=/Users/Ankur/Library/Arduino15/packages/arduino/tools/avrdude/6.0.1-arduino5 -verbose /Users/Ankur/Google Drive/3D Printer Information/Marlin_3DP12_398/Marlin_3DP12_398.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/Ankur/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/Ankur/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/Ankur/Documents/Arduino/libraries -fqbn=arduino:avr:mega:cpu=atmega1280 -ide-version=10812 -build-path /var/folders/6f/mlpxpd056szfkr817zdxdh680000gn/T/arduino_build_883098 -warnings=none -build-cache /var/folders/6f/mlpxpd056szfkr817zdxdh680000gn/T/arduino_cache_697442 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/Users/Ankur/Library/Arduino15/packages/arduino/tools/avr-gcc/4.8.1-arduino5 -prefs=runtime.tools.avr-gcc-4.8.1-arduino5.path=/Users/Ankur/Library/Arduino15/packages/arduino/tools/avr-gcc/4.8.1-arduino5 -prefs=runtime.tools.avrdude.path=/Users/Ankur/Library/Arduino15/packages/arduino/tools/avrdude/6.0.1-arduino5 -prefs=runtime.tools.avrdude-6.0.1-arduino5.path=/Users/Ankur/Library/Arduino15/packages/arduino/tools/avrdude/6.0.1-arduino5 -verbose /Users/Ankur/Google Drive/3D Printer Information/Marlin_3DP12_398/Marlin_3DP12_398.ino
Using board 'mega' from platform in folder: /Users/Ankur/Library/Arduino15/packages/arduino/hardware/avr/1.6.7
Using core 'arduino' from platform in folder: /Users/Ankur/Library/Arduino15/packages/arduino/hardware/avr/1.6.7
Warning: platform.txt from core 'Arduino AVR Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
Detecting libraries used...
/Users/Ankur/Library/Arduino15/packages/arduino/tools/avr-gcc/4.8.1-arduino5/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega1280 -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_MEGA -DARDUINO_ARCH_AVR -I/Users/Ankur/Library/Arduino15/packages/arduino/hardware/avr/1.6.7/cores/arduino -I/Users/Ankur/Library/Arduino15/packages/arduino/hardware/avr/1.6.7/variants/mega /var/folders/6f/mlpxpd056szfkr817zdxdh680000gn/T/arduino_build_883098/sketch/Marlin_3DP12_398.ino.cpp -o /dev/null
fork/exec /Users/Ankur/Library/Arduino15/packages/arduino/tools/avr-gcc/4.8.1-arduino5/bin/avr-g++: bad CPU type in executable
Error compiling for board Arduino Mega or Mega 2560.
I have set the board to 'Arduino Mega or Mega 2560', as is the type of board.
I have set the processor to ATmega1280, this is an assumption.
Just this little hurdle and I should be ready to update.
I have attached the zip file if anyone is interested.
Any help would be greatly appreciated and thank you in advance.
Kind Regards,
AS
Marlin_3DP12_398.zip (288 KB)
