HID Gamepad - Send repeating keypresses to PC while button is held.
Hi all. Novice Arduino using working on a HID gamepad project. I have the code below working with my custom gamepad. I just want to know if I can add a feature into the code.
Desired response: If a key is held down it actually sends a signal to the PC that looks like the key is being pressed>released>pressed>released cycling every 200ms until the key is actually released.
Basically make the computer read that the user is repeatedly pressing the key when it is actually held down.
This seems to be a pretty unique feature and I am not sure if it is possible. I haven’t found any other posts that match what I am looking for.
#include <Key.h>
#include <Keypad.h>
#include <Keyboard.h>
const byte ROWS = 4; //two rows
const byte COLS = 6; //two columns
char keys[ROWS][COLS] = {
{‘D’, ‘H’, ‘L’, ‘P’, ‘T’, ‘X’},
{‘C’, ‘G’, ‘K’, ‘O’, ‘S’, ‘W’},
{‘B’, ‘F’, ‘J’, ‘N’, ‘R’, ‘V’},
{‘A’, ‘E’, ‘I’, ‘M’, ‘Q’, ‘U’}
byte rowPins[ROWS] = {1, 2, 3, 4}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5, 6, 7, 8, 9, 10}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
char customKey = customKeypad.getKey();
if (customKey) {
//Keyboard.write(“key”);
Serial.println(customKey);
if (customKey == ‘A’) {
Keyboard.write (‘A’);
if (customKey == ‘B’) {
Keyboard.write (‘B’);
if (customKey == ‘C’) {
Keyboard.write (‘C’);
if (customKey == ‘D’) {
Keyboard.write (‘D’);
if (customKey == ‘E’) {
Keyboard.write (‘E’);
if (customKey == ‘F’) {
Keyboard.write (‘F’);
if (customKey == ‘G’) {
Keyboard.write (‘G’);
if (customKey == ‘H’) {
Keyboard.write (‘H’);
if (customKey == ‘I’) {
Keyboard.write (‘I’);
if (customKey == ‘J’) {
Keyboard.write (‘J’);
if (customKey == ‘K’) {
Keyboard.write (‘K’);
if (customKey == ‘L’) {
Keyboard.write (‘L’);
if (customKey == ‘M’) {
Keyboard.write (‘M’);
if (customKey == ‘N’) {
Keyboard.write (‘N’);
if (customKey == ‘O’) {
Keyboard.write (‘O’);
if (customKey == ‘P’) {
Keyboard.write (‘P’);
if (customKey == ‘Q’) {
Keyboard.write (‘Q’);
if (customKey == ‘R’) {
Keyboard.write (‘R’);
if (customKey == ‘S’) {
Keyboard.write (‘S’);
if (customKey == ‘T’) {
Keyboard.write (‘T’);
if (customKey == ‘U’) {
Keyboard.write (‘U’);
if (customKey == ‘V’) {
Keyboard.write (‘V’);
if (customKey == ‘W’) {
Keyboard.write (‘W’);
if (customKey == ‘X’) {
Keyboard.write (‘X’);
You could try this (compiles, not tested…)
(This assumes only one key pressed at a time. I’m not sure if the Keypad library supports multiple keys pressed at once; if it does and you need that support this code would need significant changes.)
#include <Key.h>
#include <Keypad.h>
#define IS_RELEASED     false
#define IS_PRESSED      true
  {'D', 'H', 'L', 'P', 'T', 'X'},
  {'C', 'G', 'K', 'O', 'S', 'W'},
  {'B', 'F', 'J', 'N', 'R', 'V'},
  {'A', 'E', 'I', 'M', 'Q', 'U'}
char
    keyPressed,
    lastKey;
    lastKey = customKeypad.getKey();
}//setup
    static uint8_t
        stateKey = IS_RELEASED;
    static uint32_t
        timeKey;
    uint32_t
        timeNow = millis();
    char
    if( customKey != lastKey )
        if( customKey == NO_KEY )
            //transitioned from something to NO_KEY, so stop auto-repeat
        }//if
        else if( lastKey == NO_KEY )
            //transition was from NO_KEY to something pressed...
            keyPressed = customKey;
            timeKey = millis();
            Keyboard.write( customKey );
            Serial.println( customKey );
            stateKey = IS_PRESSED;
        }//if
        lastKey = customKey;
    }//if
    switch( stateKey )
        case    IS_RELEASED:
            //do nothing
        case    IS_PRESSED:
            //while in this state, every 200mS send another press of the key
            //that got us into this state
            if( timeNow - timeKey >= 200ul )
                timeKey = timeNow;
            }//if
    }//switch
}//loop
WARNING: Pin 1 is one of the Serial pins. You should not use it both for your keypad AND for Serial.
I shifted the inputs to pins 2-11.
The repeat isn’t working correctly yet. With this sketch I get two outputs per key press. (AA, BB and so on) instead of a continuous repeat when pressed.
#include <Key.h>
#include <Keypad.h>
byte rowPins[ROWS] = {2, 3, 4, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {6, 7, 8, 9, 10, 11}; //connect to the column pinouts of the keypad
char
keyPressed,
lastKey;
}//setup
static uint8_t
static uint32_t
timeKey;
uint32_t
timeNow = millis();
char
}//if
//transition was from NO_KEY to something pressed…
timeKey = millis();
}//if
}//if
switch( stateKey )
case IS_RELEASED:
//do nothing
case IS_PRESSED:
timeKey = timeNow;
}//if
}//switch
}//loop
dougn0782:
After looking at the sourcecode for the Keypad library it looks like getKey() doesn’t function as I thought; it actually looks for a state change rather than returning the currently pressed key. That means that subsequent calls to getKey aren’t going to return the value of the key being pressed.
I think you’d need to include getState(…) calls to know if a key is in the HOLD state.
Here’s another untested example. It compiles but I’ve never used Keypad before so it’s probably still a mess.
#include <Key.h>
#include <Keypad.h>
char
    keyPressed,
    lastKey;
    customKeypad.setHoldTime( 200 );
}//setup
    static uint8_t
    static uint32_t
        timeKey;
    uint32_t
        timeNow = millis();
    KeyState
        keypadState;
    char
    switch( stateKey )
        case    IS_RELEASED:
            if( customKey != NO_KEY )
                //got the first instance of the key press
                timeKey = timeNow;
            }//if
        case    IS_PRESSED:
            switch( customKeypad.getState() )
                case    HOLD:
                    //if key transitions to HOLD issue repeats every 200mS
                        timeKey = timeNow;
                    }//if
                case    RELEASED:
                    //when state shows key is released, go back to IS_RELEASED state
                default:
                    //don't care about PRESSED and IDLE states here
            }//switch
    }//switch
}//loop
Blackfin:
After looking at the sourcecode for the Keypad library it looks like getKey() doesn't function as I thought; it actually looks for a state change rather than returning the currently pressed key. That means that subsequent calls to getKey aren't going to return the value of the key being pressed.
I think you'd need to include getState(...) calls to know if a key is in the HOLD state.
Hmm, still not working. Can the basic keypad sketch be used with a delay at the end of the loop? Then have it reset with it loops again? Would that cause the output keypresses to repeat?
One way to get separate press and release events for each key is to use the MultiKey example from the Keypad library.
#include <Keypad.h>
  customKeypad.setHoldTime(200);
} //setup
  // Fills kpd.key[ ] array with up-to 10 active keys.
  // Returns true if there are ANY active keys.
  if (customKeypad.getKeys())
    for (int i = 0; i < LIST_MAX; i++) // Scan the whole key list.
      if (customKeypad.key[i].stateChanged)   // Only find keys that have changed state.
        switch (customKeypad.key[i].kstate)    // Report active key state : IDLE, PRESSED, HOLD, or RELEASED
          case PRESSED:
            Keyboard.press(customKeypad.key[i].kchar);
          case HOLD:
          case RELEASED:
            Keyboard.release(customKeypad.key[i].kchar);
          case IDLE:
}//loop
Note: Another option is the EventKeypad example.
OK, you made me get my keypad out and actually debug it. Try this:
#include <Key.h>
#include <Keypad.h>
char
    keyPressed,
    lastKey;
}//setup
    static uint8_t
    static uint32_t
        timeKey;
    uint32_t
        timeNow = millis();
    KeyState
        keypadState;
    static char
        customKey;
    switch( stateKey )
        case    IS_RELEASED:
                timeKey = timeNow;
            }//if
        case    IS_PRESSED:
            char tempchar = customKeypad.getKey();
            keypadState = customKeypad.getState();
            switch( keypadState )
                case    HOLD:
                        timeKey = timeNow;
                    }//if
                case    RELEASED:
                default:
            }//switch
    }//switch
}//loop
Awesome! Thanks to both of you. This is perfect.
What does the "200ul" stand for? I assume 200ms but don't know what ul is.
dougn0782:
What does the “200ul” stand for? I assume 200ms but don’t know what ul is.
It denotes to the compiler to consider the value – 200 – as an “unsigned long”, important when dealing with millis() or micros() which return 32-bit values.
Note: I was looking at the Keypad sources and noticed that the KeyboardEventListener feature only works for one key at a time. If you want to support simultaneous keys, use the .getKeys() function as demonstrated above.
