HID ProxPoint Skimmer help
Hello, I've been trying to develop a door controller based on this attached code I found online using a Honeywell OmniProx HID reader and a 12v door strike. It works great on 328p(I've successfully tested on Uno and Nano) but doesn't want to read data from the HID reader once I start using an Atmega2560(I'm using a Mega R3); It's almost like the Data 0 & 1 wires aren't even connected. I'm thinking that there's something specific about pins D2 & D3 on my Uno/Nano boards that's different on my Mega board like maybe I'm supposed to connect the data wires to different pins on the Mega. However, just by reading the attached code, it looks like the code is determining that the data wires get connected to pins 2 & 3 and I could hypothetically change the code so that the data wires get connected to different pins. But who knows, maybe I'm wrong. I doubt that would solve the issue anyways. So I'm just looking for some help with solving this issue. If anyone has any ideas or can point me in the right direction that'd be great, thanks!
(P.S. - I would just use an Uno/Nano but the code I'm writing is starting to use too many resources so that's why I need to use the Mega. The code I've attached here is not mine, I'm writing something based off of this code I found online. I do plan on doing a full write-up on my project and sharing the code but I'm not comfortable sharing the code yet because it's still too unreliable and very messy. Regardless, both codes are having the same issue with the Mega so I'm assuming that if we can solve the issue with the attached code, the solution will work on my code as well.)
Here is the code...
/* HID ProxPoint Skimmer
*  Brad Antoniewicz
* This is a prototype for a skimmer that sits between a
* HID ProxPoint reader and a VertX Controller
* It will take data recieved from the Reader, print it
* and send it to the controller
* It will also take data recieved from the Serial interface
* on the Arduino (in Binary) and send it to the controller
* Arduino Pinouts:
*        2 - ProxPoint Green (DATA 0)
*        3 - ProxPoint White (DATA 1)
*        8 - Output to VertX Data 0 (Green)
*        9 - Output to VertX Data 1 (White)
*        11 - VertX Strike Relay NO 1
*        12 - VertX Strike Relay NO 2
*        13 - LED
*        5V - To ProxPoint Red
*        GND - To ProxPoint Black
*        GND - To VertX Ground (Black)
*  All of the Remaining ProxPoint wires can be plugged into the VertX
*  or left out.
* 26-Bit Wiegant Format:
* Bit 1 = Even Parity over Bits 2 - 13
* Bits 2 - 9 = Facility Code (0 to 255) Bit 2 is MSB
* Bits 10 - 25 = ID Number (0 to 65,535) Bit 10 is MSB
* Bits 26 Odd parity over bits 14 to 25
* Disclaimer - I know this code is REALLY sloppy and inefficient
*          Please don't judge me :)
#define CARD_LEN 26
#define LED 13   // output LED
#define VX_D0 8  // output DATA0 (Green) to Controller
#define VX_D1 9  // output DATA1 (White) to Controller
#define VX_NO1 11 // input VertX Strike Relay NO 1
#define VX_NO2 12 // input VertX Strike Relay NO 2
unsigned long cardValue = 0;
int incomingByte = 0;
int sInputCount = 0;
/* This code is for processing data from the reader - Thanks Mike Cook!
volatile unsigned long reader1 = 0;
volatile int reader1Count = 0;
void reader1One(void) {
   reader1Count++;
   reader1 = reader1 << 1;
   reader1 |= 1;
void reader1Zero(void) {
   reader1Count++;
void isr(int action) {
   if ( action == 1 ) { // Start
/* Crazy People Timing and ISR -- Thanks Mike Cook! */
       attachInterrupt(0, reader1Zero, FALLING);//DATA0 to pin 2
       attachInterrupt(1, reader1One, FALLING); //DATA1 to pin 3
       delay(10);
   } else { // Stop
       detachInterrupt(0);
       detachInterrupt(1);
// END Reader In
void resetState() {
   Serial.println("[+] Reseting State...");
   delay(10);
   Serial.flush();
   sInputCount=0;
   reader1 = 0;
   reader1Count=0;
void writeCard(volatile unsigned long sendValue) {
     Serial.println("[-] Sending Data:");
     Serial.print("\t");
     for (short x=CARD_LEN; x>=0; x--) {
       if ( bitRead(sendValue,x) == 1 ) {
         Serial.print("1");
         digitalWrite(VX_D1, LOW);
         delayMicroseconds(34);
         digitalWrite(VX_D1, HIGH);
       } else if ( bitRead(sendValue,x) == 0 ) {
         Serial.print("0");
         digitalWrite(VX_D0, LOW);
         digitalWrite(VX_D0, HIGH);
       delay(2);
void processInput(int byte) {
    if (byte == 49) { // DECIMAL 1
      sInputCount++;
      bitSet(cardValue, CARD_LEN - sInputCount);
   } else if (byte == 48) { // DECIMAL 0
      sInputCount++;
      bitClear(cardValue, CARD_LEN - sInputCount);
   } else if (byte == 98 || byte == 66) { // b or B
       Serial.println("[-] Entering Brute Force Mode, provide starting value:");
  //    doDecBrute();
     Serial.print("[!] Recieved invalid Value:");
       Serial.println(byte);
       resetState();
void printCardData(unsigned long data) {
     int serialNumber = (data >> 1) & 0x3fff;
     int siteCode = (data >> 17) & 0x3ff;
     Serial.print("\tH: ");
     Serial.print(data,HEX);
     Serial.print(" SC: ");
     Serial.print(siteCode);
     Serial.print(" C: ");
     Serial.println(serialNumber);
     Serial.print("\tB: ");
     Serial.println(data, BIN);
/* This stuff is for the Door Sensor LED */
   pinMode(LED, OUTPUT);
   digitalWrite(LED, LOW);
   digitalWrite(LED, HIGH);
   pinMode(VX_NO1, INPUT); // Reader 1
   pinMode(VX_NO2, INPUT); // Reader 2
// End Door Sensor Stuff
/* Reader In - */
   isr(0);
   isr(1);
   for(int i = 2; i<4; i++){
     pinMode(i, OUTPUT);
     digitalWrite(i, HIGH); // enable internal pull up causing a one
     digitalWrite(i, LOW); // disable internal pull up causing zero and thus an interrupt
     pinMode(i, INPUT);
   delay(10);
   reader1 = 0;
   reader1Count = 0;
//End Reader In
   pinMode(VX_D0,OUTPUT);
   pinMode(VX_D1,OUTPUT);
  sInputCount = 0;
   Serial.begin(38400);
   Serial.println("Please provide a tag value");
   Serial.println("For Binary input, it must be 26 bits long");
   Serial.println("No parity needs, just add two 0's to the beginning");
   Serial.println("e.g. 00001001100011111110010101");
  int reader1Status = digitalRead(VX_NO1);
  int reader2Status = digitalRead(VX_NO2);
  if ( reader1Status == HIGH || reader2Status == HIGH ) {
     Serial.println("---  D o o r  U n l o c k e d ---");
     delay(4000);
/* Start Serial In
    All this stuff does is accept input via the serial interface
  if (Serial.available() > 0 ) {
     incomingByte = Serial.read();
     Serial.print(".");
     delay(10);
     processInput(incomingByte);
     if ( ( sInputCount > 0 ) && ( sInputCount != CARD_LEN ) && ( Serial.peek() == -1 ) ) {
           Serial.println("\n[!] Invalid Input Length!");
           resetState();
   if (sInputCount == CARD_LEN) {
       Serial.println("");
           Serial.println("[-] Sending current Serial Buffer");
           writeCard(cardValue);
           resetState();
      } else if (sInputCount > CARD_LEN) {
           Serial.println("[!] Sorry, looks like your input was too long.. ");
           resetState();
// End Serial In
/* Start Reader IN
     All this stuff does is take data in from the reader
     then send it to the controller
 if(reader1Count >= 26){
     Serial.println("");
     Serial.println("[+] Recieved input from Reader:");
     Serial.println("-------------------------------");
     printCardData(reader1);
     Serial.println("[+] Sending input to Controller:");
     writeCard(reader1);
     resetState();
    // END Reader IN
Found the solution on another forum post Here
