My kids race Soap Box Derby (not Pinewood) and we have been using the same relay based lane timers since the late 70's. These timers work quite well and provide an accuracy down to 0.001 and are generally fairly accurate over a varied temperature range (we race in just about anything from 30F with Snow to 110F with rain)
Before anyone points this out, I've looked at the Pinwood Derby stuff at Pinewood Derby Race Timer already. Several times. I've also noticed a lot of posts about the inaccuracy of the oscillator over varied temperature ranges.
My goals are as follows:
Differential time between 2-3 lanes (2 here on our track, but some other tracks like Akron use 3 lanes)
Overall elapsed time for a given lane, sampled at 4 intervals (top, 1/3 down, 2/3 down, bottom) for each lane
Extremely accurate event given varied temperatures
Added bonus would be speed at each interval, should be a simple calculation of length of car / time spent blocking I would think
Why am I worried about the lane samples and accuracy? Simple, we like to try different things; positions on the track, torque, camber, toe, etc... under different circumstances; wet track, dry track, rain, snow, sleet, etc... Since it isn't uncommon (happens at least once a race) to see differences of 0.001 accuracy matters when trying to tune your car (or driver).
Any guidance would be greatly appreciated. I realize I'll probably have to change out the existing oscillator with a TCXO or something similar. Options? What works, what doesn't?
Oh, and we use a low power laser (think cheap laser pointer) from the center of the track to the outsides to determine each lane. I'd love to find a way to do this with a single source across both lanes, or dual sources from either side, but I'm not sure that is actually possible since you can't really tell what car passed and exited when with such a setup.
PS: I should mention that the distance from start to finish is anywhere from 900-1100ft using Cat5 cable to carry the signal/power to all sensors. As I know that line distance makes a difference we also ensure that all lines are the same length with minimum coil
Thanks in advance,
- Jeremy
