Hi Arduino Community!
I'm working with Arduino for a few weeks now and i do have some coding knowledge. However, as it seems i cannot figure out the problem i'm facing. Maybe you can help me!
My goal is to use an Arduino UNO with an 200g-accelerometer to sample at a >500Hz rate (for a few minutes) and log the data over a serial connection. After some literature research and following trials im sticking with this:
My Arduino Code:
//some declarations...
//Initialize Program on LCD
LiquidCrystal lcd(0);
lcd.begin(20,4);
lcd.setBacklight(HIGH);
lcd.print(" TEST ENVIRONMENT ");
lcd.setCursor(0, 2);
lcd.print(" Preparing... ");
lcd.setCursor(0, 3);
lcd.print("PRESS ENTER TO START");
// Serial connection
delay(2000);
Serial.println("Starting Test Program");
// pins
pinMode(ledPin,OUTPUT);
pinMode(sensorPin, INPUT);
while(1) {
//Serial.println(digitalRead(button));
if(digitalRead(button)==1) {
lcd.print("TRANSMISSION ONGOING");
lcd.print("--------------------");
} // end SETUP
//Sending Sensor data over serial
//sensValue=analogRead(sensorPin);
sensValue+=1;
time_us = micros();
Serial.print('H'); // sends 1 byte
sendBinary(time_us); // sends 4 byte
sendBinary(sensValue); // sends 2 byte
delay(10);
} // end LOOP
// Functions
void sendBinary(int value)
// Send 2 bytes
Serial.write(lowByte(value));
Serial.write(highByte(value));
void sendBinary(unsigned long value)
// Split 32bit long into lower 16bit integer value...
int temp = value && 0xFFFF;
sendBinary(temp);
// ...and higher 16bit integer
temp = value >> 16;
sendBinary(temp);
For first debugging purposes i used a counter instead of the sensor data.
Here's the other end of the serial connection using a simple Processing Script:
//Some declarations:
void setup () {
// List all the available serial ports
println(Serial.list());
// Check the listed serial ports in your machine
// and use the correct index number in Serial.list()[].
myPort = new Serial(this, portName, 115200); //
File f = new File("data.txt");
if (f.exists()) {
f.delete();
fileOut = createWriter("data.txt");
void draw () {
if ( myPort.available() >= 7) // If at least 7 bytes are available, {
if (myPort.read() == HEADER)
// Read in Long (2x2xByte)
int_longA = myPort.read();
int_longA = myPort.read() * 256 + int_longA;
int_longB = myPort.read();
int_longB = myPort.read() * 256 + int_longB;
longValue = 256*256*int_longB + int_longA;
// Read in Integer (2xByte)
intValue = myPort.read();
intValue = myPort.read()*256 + intValue;
println( longValue + " " + intValue); //Console Print Out
fileOut.println(longValue + ", " + intValue); //File Print Out
void keyPressed() {
fileOut.flush(); // Writes the remaining data to the file
fileOut.close(); // Finishes the file
exit(); // Stops the program
Works fine for delays of 100ms on the Arduino side.
For a delay of 10ms (so i can get a maximum sampling rate of <100Hz) the data shows duplicate values for the time (in microseconds) which is weird.
data.txt:
4915201, 1
4980737, 2
4980737, 3
4980737, 4
4980737, 5
4980737, 6
4980737, 7
4980737, 8
5046273, 9
5046273, 10
5046273, 11
5046273, 12
5046273, 13
5046273, 14
5111809, 15
5111809, 16
5111809, 17
5111809, 18
5111809, 19
5111809, 20
5111809, 21
5177345, 22
5177345, 23
5177345, 24
5177345, 25
5177345, 26
5177345, 27
5242881, 28
5242881, 29
5242881, 30
So i think Arduino does not update the time_us variable, but why not?
- Any inputs on how to solve/improve this?
- Is the binary approach i'm using here the most efficient for this application?
- Where is the bottleneck for such a high frequency data logging system? Arduino, Serial connection? or the receiving end?
- I also tried to plot the data in real time (in Matlab) for high frequencies, which didnt work. It froze my peripherals, probably due to a buffer overflow since my Mac couldnt keep up with the arduino (?). Is it even possible to plot this data in real-time? Any thoughts?
Thank you in advance!
