system
July 11, 2012, 2:02pm
#1
Hello.
I have a question about a project that I am starting.
What I have
5 meters of led strip (http://www.sparkfun.com/products/10260 )
14.4V power supply
Arduino
What I need
I want to let the arduino to set 0-12V (variable voltage) to each R/G/B wire, by using external power supply.
Because the whole chain takes 6000 mA @ 12.0V
What I know
The PWM ports can only output 0-5V, and 60 mA per channel.
Can anybody direct me to the right direction, which components are best here?
Linear Regulators, Shift Register or what.
What is the easiest way?
system
July 11, 2012, 2:28pm
#2
What I know
You might want to check this fact. The recommended upper limit is usually 40mA, with 20mA being recommended for long term use.
You can use a transistor to control each leg. Transistors can toggle at PWM speeds, and can control that amount of current.
system
July 11, 2012, 2:30pm
#3
sp. "The PWM ports can only output 0 or 5V"
system
July 11, 2012, 2:54pm
#4
Whoops... thanks for the correction.
so a PWM pin set to 50% duty cycle, connected to transistor and external power supply, should give me 50% brightness on led strip ?
How do you hook up an transistor to external power supply?
system
July 11, 2012, 3:20pm
#6
Can these transistors, like BC546, hold up to 2A@12V ?
the datasheet says 100 mA / 500 mW.
Any other solution ?
You'll need to look at the datasheets for various transistors...
