High Power Consumption During Deep Sleep on Seeed Studio Xiao ESP32S3
Hello everyone,
I am working on a project using the Seeed Studio Xiao ESP32S3, and I am facing challenges in achieving low power consumption during deep sleep mode. Despite following multiple steps to optimize power usage, I am still observing relatively high current draw. I would greatly appreciate your insights and suggestions to resolve this issue.
  • Deep Sleep Consumption: Around 100 mA (measured using a Nordic Power Profiler Kit II).
  • Expected Consumption: 4mA , as indicated by the datasheet.
#include "esp_camera.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include <HTTPClient.h>
#include <ArduinoJson.h>
// Camera configuration pins
#define PWDN_GPIO_NUM     -1
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM     10
#define SIOD_GPIO_NUM     40
#define SIOC_GPIO_NUM     39
#define Y9_GPIO_NUM       48
#define Y8_GPIO_NUM       11
#define Y7_GPIO_NUM       12
#define Y6_GPIO_NUM       14
#define Y5_GPIO_NUM       16
#define Y4_GPIO_NUM       18
#define Y3_GPIO_NUM       17
#define Y2_GPIO_NUM       15
#define VSYNC_GPIO_NUM    38
#define HREF_GPIO_NUM     47
#define PCLK_GPIO_NUM     13
// Wi-Fi credentials
const char* ssid = "********";
const char* password = "*********";
// Server endpoints
const char* serverHost = "*****"; // Network ip from cmd-ipconfig
const int serverPort = 8080;
const char* loginEndpoint = "/api/v1/user/login";
const char* uploadEndpoint = "/api/v1/image/add-image";
// Deep sleep settings
#define uS_TO_S_FACTOR 1000000ULL  // Conversion factor for microseconds to seconds
#define TIME_TO_SLEEP  10          // Time ESP32 will sleep (in seconds)
// Global variables
String authToken = ""; // Authentication token
  // Intializations
  Serial.println("Starting setup...");
    camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  config.frame_size = FRAMESIZE_VGA;
  config.jpeg_quality = 5; // Adjust as needed ( lower means better quality)
  config.fb_count = 1;
  // Connect to Wi-Fi
  Serial.print("Connecting to Wi-Fi...");
  WiFi.begin(ssid, password);
    delay(200);
    Serial.print(".");
      Serial.println("\nConnected to Wi-Fi");
  // Initialize the camera
  if (esp_camera_init(&config) != ESP_OK) {
    Serial.println("Camera initialization failed");
    while (true); // Halt
    Serial.println("Camera initialized.");
      // Authenticate with the server
  if (!authenticate()) {
    Serial.println("Authentication failed. Halting...");
  Serial.println("Authentication successful.");
  Serial.println("Capturing image...");
    camera_fb_t *fb = esp_camera_fb_get();
    if (!fb) {
      Serial.println("Image capture failed");
      delay(5000);
      return;
    // Upload the image
    if (uploadImage(fb)) {
      Serial.println("Image uploaded successfully.");
      Serial.println("Failed to upload image.");
    // Return the frame buffer to the driver for reuse
    esp_camera_fb_return(fb);
    // Configure the wake-up timer
    esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
    Serial.println("Entering deep sleep for " + String(TIME_TO_SLEEP) + " seconds...");
    Serial.println("Going to sleep now");
    //prepare for sleep
    Serial.flush();
    // Disable Wi-Fi
    WiFi.disconnect(true);
    WiFi.mode(WIFI_OFF);
    delay(100); // Short delay to ensure Wi-Fi is off
    // Disable Bluetooth
    btStop();
    delay(100); // Short delay to ensure Bluetooth is off
    // Deinitialize camera
    esp_camera_deinit();
    // Power down the camera
    if (PWDN_GPIO_NUM != -1) {
        pinMode(PWDN_GPIO_NUM, OUTPUT);
        digitalWrite(PWDN_GPIO_NUM, HIGH); // Power down the camera
    //Going to sleep
    esp_deep_sleep_start();
bool authenticate() {
  HTTPClient http;
  String url = String("http://") + serverHost + ":" + serverPort + loginEndpoint;
  http.begin(url);
  http.addHeader("Content-Type", "application/json");
  // Prepare JSON payload
  StaticJsonDocument<256> jsonDoc;
  jsonDoc["login"]["username"] = "admin";
  jsonDoc["login"]["password"] = "admin";
  jsonDoc["device"]["deviceName"] = "Device2";
  jsonDoc["device"]["deviceSchool"] = "School1";
  String requestBody;
  serializeJson(jsonDoc, requestBody);
  Serial.println("Sending authentication request...");
  int httpResponseCode = http.POST(requestBody);
  if (httpResponseCode == 200) {
    String response = http.getString();
    Serial.println("Authentication response:");
    Serial.println(response);
    StaticJsonDocument<512> responseDoc;
    DeserializationError error = deserializeJson(responseDoc, response);
    if (error) {
      Serial.print("deserializeJson() failed: ");
      Serial.println(error.f_str());
      http.end();
      return false;
    // Extract token based on actual response structure
    if (responseDoc.containsKey("token")) {
      authToken = responseDoc["token"].as<String>();
    } else if (responseDoc["data"]["token"]) {
      authToken = responseDoc["data"]["token"].as<String>();
      Serial.println("Token not found in authentication response.");
      http.end();
      return false;
    Serial.print("Received token: ");
    Serial.println(authToken);
    http.end();
    return true;
    Serial.print("Authentication failed, HTTP response code: ");
    Serial.println(httpResponseCode);
    String errorResponse = http.getString();
    Serial.println("Error response:");
    Serial.println(errorResponse);
    http.end();
    return false;
bool uploadImage(camera_fb_t *fb) {
  WiFiClient client;
  if (!client.connect(serverHost, serverPort)) {
    Serial.println("Connection to server failed");
    return false;
  // Generate boundary string
  String boundary = "------------------------" + String(millis());
  // Prepare HTTP request
  String head = "--" + boundary + "\r\n" +
                "Content-Disposition: form-data; name=\"image\"; filename=\"photo.jpg\"\r\n" +
                "Content-Type: image/jpeg\r\n\r\n";
  String tail = "\r\n--" + boundary + "--\r\n";
  // Calculate content length
  size_t contentLength = head.length() + fb->len + tail.length();
  // Send HTTP POST request
  client.print("POST " + String(uploadEndpoint) + " HTTP/1.1\r\n");
  client.print("Host: " + String(serverHost) + "\r\n");
  client.print("Content-Type: multipart/form-data; boundary=" + boundary + "\r\n");
  client.print("authorization: " + authToken + "\r\n");
  client.print("Content-Length: " + String(contentLength) + "\r\n");
  client.print("Connection: close\r\n\r\n");
  // Send HTTP body
  client.print(head);
  client.write(fb->buf, fb->len);
  client.print(tail);
  Serial.println("Image data sent. Waiting for server response...");
  // Read server response
  unsigned long timeout = millis();
  while (!client.available()) {
    if (millis() - timeout > 10000) {
      Serial.println("Server response timed out");
      client.stop();
      return false;
  // Read and print the response
  String response = client.readString();
  Serial.println("Server response:");
  client.stop();
  // Check for success
  if (response.indexOf("200 OK") != -1 || response.indexOf("\"status\":\"success\"") != -1) {
    return true;
    return false;
The board should connect to wifi , take a pic , upload it to a server , go sleep.
Once the OV2640 camera is turned on, you cannot turn it off for deep sleep.
Issue is discussed at length in the SEEED support forum;
https://forum.seeedstudio.com/t/xiao-esp32s3-sense-camera-sleep-current/271258/39
There is a solution offered, but you need to change the camera.
Thank you so much , I will check that
I moved your topic to a more appropriate forum category @sherif247 .
The Nano ESP32 category you chose is only used for discussions directly related to the Arduino Nano ESP32 board.
In the future, please take the time to pick the forum category that best suits the subject of your question. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Thanks in advance for your cooperation.
I will take care of the in the future and be more careful. Thanks :slight_smile:
