High power LED switching
Hello all,
I am trying to control a 20W LED using a tip122 transistor. I am using PWM to control the brightness of the LED. The transistor gets dangerously hot after switching the LED for a few minutes. I have a 1KOhm resistor at the base for the control signal (attached circuit diagram). I believe the transistor cannot handle the load current and hence is dissipating heat.
My questions: what is a good way to control high power LEDs? and particularly a 20W LED.
and how is the PWM frequency related to the heat dissipated by the transistor?
Bad choice of transistor - Darlingtons are pretty much obsolete.
You need a logic level - note that - power FET. I haven't used them myself yet, but others will offer a lot of choices if you cannot research that yourself.
Post a link to the 20watt LED.
It could be a 20watt cob LED that needs a proper LED driver module, not just a transistor.
Leo..
Well, if it is a bare COB LED, then the TIP122 will be just fine, will just need to add a heatsink and use this circuit:
Where the TIP122 substitutes for the second transistor and the base resistor is your 1k.
For 2 Amps to the COB, "R" would be about 0.33 Ohm.
20watt with a LED Vf of about 10volt is 2Amp.
The TIP122 has a Vce(sat) of ~1volt at that collector/base current.
That's a dissipation of 2watt in the transistor.
No surprise it gets sizzling hot.
Datasheet recommends a base:collector current of 1:250 for full saturation, so changing the base resistor to 470ohm could lower dissipation somewhat.
The above circuit is easier on the LED (limits current to a safe value), but could be harder on the transistor.
If the transistor has to drop 2volt, dissipation could be 4watt.
A proper switching LED driver would barely get warm with those currents.
Leo..
Thanks guys. But no luck yet.
@Wawa this is the LED I'm trying to control: https://www.amazon.com/gp/product/B00RCSAQWK/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
it goes to 1.78amps at 12V.
Though it doesn't say it anywhere I'm pretty sure it is NOT a COB. I tried switching the TIP122 with an RFP30N06LE n-channel power MOSFET now the LED doesn't turn on. I'm using this kit SparkFun MOSFET Power Control Kit - COM-12959 - SparkFun Electronics with a 10Kohm resistor. My power source is a 12V Li-ion battery pack.
That's a floodlight, most likely with a LED driver inside.
Dimming that floodlight externally could be impossible.
The internal LED driver (if it has one) will fight that.
And yes, that yellow square is a cob LED.
Leo..
Oh damn! never considered the fact that there could be a driver inside it. Thanks Leo..!
Link corrected.
Wawa:
It is specified 12 to 24 V.
That means it does have a switchmode power converter inside with capacitors that most certainly will prevent you using PWM. The internal driver might be able to be modified but as you gather - it's simply not worth it.
