High Resolution Gyro Question
yes, kind of. You need to be careful about when you memorise the previous values and handle CTS
may be something like this would be "cleaner":
#include <LiquidCrystal.h>
LiquidCrystal lcd(10, 9, 8, 7, 6, 5);       // put your pin numbers here
const byte lcdContrastPin = 11;   // LCD CONTRAST PIN
const byte CTSPin = 2;            // Clear To Send PIN
const byte RSPin = 3;             // Request Sample PIN
byte DMM_ARRAY[6];                // Where to store the Bytes read
bool Get_data() {
  bool success = (Serial.available() >= 6);
  if (success) Serial.readBytes(DMM_ARRAY, 6);
  return success;
  pinMode(CTSPin, OUTPUT);
  pinMode(RSPin, OUTPUT);
  pinMode(lcdContrastPin, OUTPUT);
  analogWrite(lcdContrastPin, 50);    //LCD CONTRAST AMOUNT
  Serial.begin(1000000);
  lcd.begin(16, 2);
  lcd.print(F("GG1320AN21 TEST"));
  static float previousValue = 0;
  unsigned long previousMicros = 0;
  float deltaTheta;
  unsigned long currentMicros = micros();    // you could do this with millis() too, depends on the precision you want
  if (currentMicros - previousMicros >= 1000000ul) { // 1s in µs
    unsigned long deltaT = currentMicros - previousMicros; // that will be give or take 1s
    digitalWrite(CTSPin, HIGH);     // CTS Open
    digitalWrite(RSPin, HIGH);      // RS
    delayMicroseconds(50);
    digitalWrite(RSPin, LOW);       //RS
    if (Get_data()) {               //Read the Serial bytes coming in
      float currentValue = DMM_ARRAY[2];
      delayMicroseconds( 200 );
      digitalWrite(CTSPin, LOW);  // CTS Close
      deltaTheta = ((previousValue - currentValue) * 1.113065); // count * 1.113065   ARC SEC / SEC
      lcd.clear();
      lcd.setCursor(0, 0);
      lcd.print(deltaTheta / (deltaT / 1000000.0)); //3 decimal place values
      lcd.setCursor(0, 1);
      lcd.print(DMM_ARRAY[2]);// Print btye 3 (LSB)
      previousValue = currentValue;
      previousMicros = currentMicros;
    } else digitalWrite(CTSPin, LOW);  // CTS Close
(typed here from your code, fully untested)
I needed to remove the else statement at the bottom as it was locking in that state and would then not send any more pulses (I think).
I removed it and now it is sending quite a fast stream of values. Not sure why it is not sending at the 1 sec intervals it was previously.
J-M-L, thank you! appreciate you cleaning it up!!
you have digitalWrite(CTSPin, HIGH); // CTS Open that is done always after 1s but you make it LOW only if you got the data, so the idea was to make it LOW in both cases.
or may be you want to move the whole section
into the if (Get_data()) {
so like this
bool Get_data() {
  return success;
  lcd.begin(16, 2);
  float deltaTheta;
    if (Get_data()) {                                           // Read the Serial bytes coming in
      digitalWrite(RSPin, LOW);       // RS
      lcd.clear();
