High resolution noise (volume) sensor?
Well, that depends. Modern rail-rail op amps work well when you use the input bias circuit you have shown, provided the input does not exceed the supply voltages.
However the dynamic range of music would be best represented with a log response - so you need a peak detector AND a non-linear amplifier.
