High resolution noise (volume) sensor?
Been following along, an interesting subject and discussion.
Anyways.
While its not in the same direction the OP wants to go in but I did do a project of lighting an LED strip with light intensity matching incoming sound levels. The unit has been working for several years now and here is my code.
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h"
#include "sdkconfig.h"
#include "esp32/ulp.h"
#include "driver/rtc_io.h"
#include "esp_system.h" //This inclusion configures the peripherals in the ESP system.
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/event_groups.h"
#include <Adafruit_NeoPixel.h>
#include "AudioAnalyzer.h"
/* define event group and event bits */
EventGroupHandle_t eg;
#define evtDo_AudioReadFreq       ( 1 << 0 ) // 1
QueueHandle_t xQ_LED_Info;
//const int LED_COUNT = 24; //total number of leds in the strip
const int LED_COUNT = 108; //total number of leds in the strip
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
Adafruit_NeoPixel leds = Adafruit_NeoPixel( LED_COUNT, 26, NEO_GRB + NEO_KHZ800 );
WiFiClient wifiClient;
PubSubClient MQTTclient(mqtt_server, mqtt_port, wifiClient);
SemaphoreHandle_t sema_MQTT_KeepAlive;
void ULP_BLINK_RUN(uint32_t us);
  ULP_BLINK_RUN(100000);
  eg = xEventGroupCreate();
  int FreqVal[7]; // used to set queue size
  xQ_LED_Info = xQueueCreate ( 1, sizeof(FreqVal) );
  sema_MQTT_KeepAlive = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive );
  // setting must be set before a mqtt connection is made
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds
  connectToWiFi();
  connectToMQTT();
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 7000, NULL, 5, NULL, 1 );
  xTaskCreatePinnedToCore( fDo_AudioReadFreq, "fDo_ AudioReadFreq", 30000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fDo_LEDs, "fDo_ LEDs", 30000, NULL, 3, NULL, 1 );
  xEventGroupSetBits( eg, evtDo_AudioReadFreq );
} // setup()
void loop() {} // void loop
void fMQTT_Disconnect(  )
  MQTTclient.disconnect();
void GetTheTime()
  char* ntpServer = "2.us.pool.ntp.org";
  int gmtOffset_sec = -(3600 * 7 );
  int daylightOffset_sec = 3600;
  configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
  printLocalTime();
// http://www.cplusplus.com/reference/ctime/strftime/
void MQTTkeepalive( void *pvParameters )
  int keepCount = 0;
  for (;;)
    log_i( " mqtt keep alive run." );
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      //      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); //
      MQTTclient.loop();
      //      xSemaphoreGive( sema_MQTT_KeepAlive );
    else {
      log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
    vTaskDelay( 4900 );
    keepCount++;
    log_i( "%d", keepCount );
    if ( keepCount >= 5 )
      fMQTT_Disconnect();
      keepCount = 0;
  vTaskDelete ( NULL );
int getHour()
  struct tm timeinfo;
  getLocalTime(&timeinfo);
  char _time[ 5 ];
  strftime( _time, 80, "%T", &timeinfo );
  return String(_time).toInt();
void printLocalTime() {
  struct tm timeinfo;
  char _time[ 80 ];
  log_i( "%s", _time);
void connectToMQTT()
  log_i( "connect to mqtt" );
  while ( !MQTTclient.connected() )
    MQTTclient.connect( clientID, mqtt_username, mqtt_password );
    log_i( "connecting to MQTT" );
    vTaskDelay( 250 );
  log_i("MQTT Connected");
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe( mqtt_topic );
void connectToWiFi()
  log_i( " Begin Connect to wifi" );
  while ( WiFi.status() != WL_CONNECTED )
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    log_i(" waiting on wifi connection" );
    vTaskDelay( 4000 );
  log_i( "End connected to WiFi" );
  WiFi.onEvent( WiFiEvent );
  GetTheTime();
static void mqttCallback(char* topic, byte * payload, unsigned int length)
  //xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY);
  //str_eTopicPtr = topic + '\0';
  int i = 0;
  String temp = "";
  for ( i; i < length; i++) {
    temp += ((char)payload[i]);
  log_i( " topic %s payload %s", topic, temp );
  //  strPayloadPtr[i] = '\0';
  // xSemaphoreGive ( sema_MQTT_KeepAlive );
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
void fDo_LEDs( void *pvParameters )
  const int Brightness = 200;
  const int SEG = 6; // how many parts you want to separate the led strip into
  const int ledCount = LED_COUNT; //total number of leds in the strip
  int iFreqVal[7];
  int j;
  leds.begin(); // Call this to start up the LED strip.
  clearLEDs( ledCount );  // This function, defined below, de-energizes all LEDs...
  leds.show();  // ...but the LEDs don't actually update until you call this.
  leds.setBrightness( Brightness ); //  1 = min brightness (off), 255 = max brightness.
  for (;;)
    if (xQueueReceive( xQ_LED_Info, &iFreqVal,  portMAX_DELAY) == pdTRUE)
      j = 0;
      //assign different values for different parts of the led strip
      for (j = 0; j < ledCount; j++)
        if ( (0 <= j) && (j < (ledCount / SEG)) )
          //log_i( "segment 0 %d", iFreqVal[0] );
          set( j, iFreqVal[0], ledCount, SEG ); // set the color of led
        else if ( ((ledCount / SEG) <= j) && (j < (ledCount / SEG * 2)) )
        else if ( ((ledCount / SEG * 2) <= j) && (j < (ledCount / SEG * 3)) )
        else if ( ((ledCount / SEG * 3) <= j) && (j < (ledCount / SEG * 4)) )
        else if ( ((ledCount / SEG * 4) <= j) && (j < (ledCount / SEG * 5)) )
      leds.show();
  vTaskDelete( NULL );
} // void fDo_ LEDs( void *pvParameters )
void fDo_AudioReadFreq( void *pvParameters )
  int FreqVal[7];
  const int NOISE = 10; // noise that you want to chop off
  const int A_D_ConversionBits = 4096; // arduino use 1024, ESP32 use 4096
  Analyzer Audio = Analyzer( 5, 15, 36 );//Strobe pin ->15  RST pin ->2 Analog Pin ->36
  Audio.Init(); // start the audio analyzer
  int64_t EndTime = esp_timer_get_time();
  int64_t StartTime = esp_timer_get_time(); //gets time in uSeconds like Arduino Micros
  for (;;)
    xEventGroupWaitBits (eg, evtDo_AudioReadFreq, pdTRUE, pdTRUE, portMAX_DELAY);
    EndTime = esp_timer_get_time() - StartTime;
    // log_i( "TimeSpentOnTasks: %d", EndTime );
    Audio.ReadFreq(FreqVal);
    for (int i = 0; i < 7; i++)
      FreqVal[i] = constrain( FreqVal[i], NOISE, A_D_ConversionBits );
      FreqVal[i] = map( FreqVal[i], NOISE, A_D_ConversionBits, 0, 255 );
      // log_i( "Freq %d Value: %d", i, FreqVal[i]);//used for debugging and Freq choosing
    xQueueSend( xQ_LED_Info, ( void * ) &FreqVal, 0 );
} // fDo_ AudioReadFreq( void *pvParameters )
//the following function set the led color based on its position and freq value
void set(byte position, int value, int ledCount, int segment)
  int valueLowLimit = 20;
  // segment 0, red
  if ( (0 <= position) && (position < ledCount / segment) ) // segment 0 (bottom to top)
    if ( value <= valueLowLimit )
      leds.setPixelColor( position, 0, 0, 0 );
      leds.setPixelColor( position, leds.Color( value , 0, 0) );
  else if ( (ledCount / segment <= position) && (position < ledCount / segment * 2) ) // segment 1 yellow
      leds.setPixelColor(position, leds.Color(0, 0, 0));
      leds.setPixelColor(position, leds.Color( value, value, 0)); // works better to make yellow
  else if ( (ledCount / segment * 2 <= position) && (position < ledCount / segment * 3) ) // segment 2 pink
      leds.setPixelColor(position, leds.Color( value, 0, value * .91) ); // pink
  else if ( (ledCount / segment * 3 <= position) && (position < ledCount / segment * 4) ) // seg 3, green
      leds.setPixelColor(position, leds.Color( 0, 0, 0));
    else //
      leds.setPixelColor( position, leds.Color( 0, value, 0) ); //
  else if ( (ledCount / segment * 4 <= position) && (position < ledCount / segment * 5) ) // segment 4, leds.color( R, G, B ), blue
    else //
      leds.setPixelColor(position, leds.Color( 0, 0, value) ); // blue
  else // segment 5
      leds.setPixelColor( position, leds.Color( value, value * .3, 0) ); // orange
} // void set(byte position, int value)
void clearLEDs( int ledCount)
  for (int i = 0; i < ledCount; i++)
    leds.setPixelColor(i, 0);
} // void clearLEDs()
void WiFiEvent(WiFiEvent_t event)
  // log_i( "[WiFi-event] event: %d\n", event );
  switch (event)
    case SYSTEM_EVENT_STA_CONNECTED:
      log_i("Connected to access point");
      break;
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
      break;
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
  Each I_XXX preprocessor define translates into a single 32-bit instruction. So you can count instructions to learn which memory address are used and where the free mem space starts.
  To generate branch instructions, special M_ preprocessor defines are used. M_LABEL define can be used to define a branch target.
  Implementation note: these M_ preprocessor defines will be translated into two ulp_insn_t values: one is a token value which contains label number, and the other is the actual instruction.
  size_t load_addr = 0;
  RTC_SLOW_MEM[12] = 0;
  ulp_set_wakeup_period(0, us);
  const ulp_insn_t  ulp_blink[] =
    I_MOVI(R3, 12),                         // #12 -> R3
    I_LD(R0, R3, 0),                        // R0 = RTC_SLOW_MEM[R3(#12)]
    M_BL(1, 1),                             // GOTO M_LABEL(1) IF R0 < 1
    I_WR_REG(RTC_GPIO_OUT_REG, 26, 27, 1),  // RTC_GPIO2 = 1
    I_SUBI(R0, R0, 1),                      // R0 = R0 - 1, R0 = 1, R0 = 0
    I_ST(R0, R3, 0),                        // RTC_SLOW_MEM[R3(#12)] = R0
    M_BX(2),                                // GOTO M_LABEL(2)
    M_LABEL(1),                             // M_LABEL(1)
    I_WR_REG(RTC_GPIO_OUT_REG, 26, 27, 0),// RTC_GPIO2 = 0
    I_ADDI(R0, R0, 1),                    // R0 = R0 + 1, R0 = 0, R0 = 1
    M_LABEL(2),                             // M_LABEL(2)
    I_HALT()                                // HALT COPROCESSOR
  const gpio_num_t led_gpios[] =
    GPIO_NUM_2,
    // GPIO_NUM_0,
    // GPIO_NUM_4
  for (size_t i = 0; i < sizeof(led_gpios) / sizeof(led_gpios[0]); ++i) {
    rtc_gpio_init(led_gpios[i]);
    rtc_gpio_set_direction(led_gpios[i], RTC_GPIO_MODE_OUTPUT_ONLY);
    rtc_gpio_set_level(led_gpios[i], 0);
  size_t size = sizeof(ulp_blink) / sizeof(ulp_insn_t);
  ulp_process_macros_and_load( load_addr, ulp_blink, &size);
  ulp_run( load_addr );
} // void ULP_BLINK_RUN(uint32_t us)
I went with the thought if 255,0,0 is red then what is 1,0,0? Well it turns out 1,0,0 is red too. A way to equal sound intensity to light intensity.
I use a DFRobot Audio Analyzer with a the Audio Analyzer modified to work with the ESP32's A:D API directly.
