High-speed multi-gigabit 60GHz WiFi, speeds of up to 4.6Gbps
2016 is the year of multi-gigabit 802.11ad WiFi. At least, according to Qualcomm, it is. WiFi speeds of up to 4.6Gbps, High-speed multi-gigabit 60GHz WiFi: Coming soon to a TP-Link router near you.
https://recombu.com/digital/article/wifi-ad-tp-link-ad7200-router
https://forum.arduino.cc/index.php?topic=350002.msg2414954#msg2414954
The second generation Yun (Tian) supports 5GHz WiFi. The third generation Yun supports 60GHz WiFi?
There is no fastest, only faster.
sonnyyu:
Let WS(x) be the WiFi speed for a chip set x; if WS(C) >= WS(Ci), for any chip set C and Ci, the chip set C has the fastest WiFi speed of all chip sets :wink:
kind regards,
Jos (<-- just being silly)
Li-Fi has just been tested in the real world, and it's 100 times faster than Wi-Fi. 4,869% faster than 60GHz WiFi. With scientists achieving speeds of 224Gbps in the lab using Li-Fi earlier last year (2015)
http://www.sciencealert.com/li-fi-tested-in-the-real-world-for-the-first-time-is-100-times-faster-than-wi-fi
It would not take long to fill (or empty) a Yun RAM at 4.6Gbps.
Is such a speed really useful for a Yun?
...R
Robin2: It would not take long to fill (or empty) a Yun RAM at 4.6Gbps.
...R
How about Yun V?
sonnyyu: How about Yun V?
You tell me!
Personally I don't see the point in small boards evolving to acquire most of the capabilities of a laptop - it's not as if laptops are prohibitively expensive.
Just because you CAN does not mean your SHOULD.
...R
Arduino Yun V: Intel® Galileo Gen2
https://www.arduino.cc/en/ArduinoCertified/IntelGalileoGen2
http://store-usa.arduino.cc/products/e000037
Dell Wireless Dw1601 Qca9005 8v256 Wigig 802.11ad 7gbps Half Mini Wireless Card
http://www.amazon.com/dp/B00K0DHWRG?tag=wiki085-20
Caution you need compile Qca9005 driver yourself since it is at early stage.
|500x500
|500x328
sonnyyu: Caution you need compile Qca9005 driver yourself since it is at early stage.
That won't be necessary as I won't be using it. :)
My 8Mhz Atmega 328 with an nRF24 is fine.
...R
