If I do LLT level mosfet switching with PMW module to drive motor, HOW can I increase mosfet switching speed.
Please suggest any combination of discrete components or IC.
Thanks
Thanks
What is an LLT mosfet?
What particular MOSFET. What is it switching (voltage, current, load type - inductive makes a real difference), how fast do you need it to switch and why? Are you worried about PWM speed or heating effects or....?
The only general answer I can think of is - use a good MOSFET driver IC.
Steve
TTL perhaps? ie logic-level. There are many 1000's of MOSFET gate driver chips of all sorts out there,
perhaps you need to explain what performance you need - current, switching speed, etc etc. What
topology is your circuit, etc etc.
