I have made a project that triggers a flashgun when a light barrier is broken or sound is registered depending on the sensor. The pot is added so i can tune the delay between the sensor being triggered and the flash firing.
All is working well except there is a obvious delay (from the photographs taken of a crossbow bolt hitting various items)and the flash firing. The LCD (16x2) is used to display the delay.
When I remove the LCD from the sketch all is well and I can capture excellent shots of crossbow bolt (200 at velocity of fps) and and a pellet (400 fps) hitting various items.
Question is, do I have to do without the LCD screen and just use the 'feel' of the pot position or is there a way of integrating the LCD without slowing down the speed between detection and firing of the flashgun. I am assuming the part of the sketch for the LCD is the problem.
Danksy:
of course there is.. first if you could indent your code properly and don't put more than 1 '}' on a line, it would greatly increase the readability (wow that actually is a word..)
Don't continuously write to the LCD ! create a separate function writing the delay and only call it if the delay-value has been altered. Do the same for the mode. Now your code should work more or less at the same speed it was without the LCD (only a change in the delay slows it down temporarily)
