My Google skills have been slacking and I can't seem to find a sensor that can take that much heat. I am also very new to this world and may not be sure what else or where to search.
I see the DHT11 all over the place, they just are not rated to withstand that heat. Any direction or advice would be much appreciated.
eDaddi:
Hey thanks for the reply, I'm actually using one of those in this project. They don't do humidity though. I'm looking for a humidity sensor that can withstand sitting in a box that gets up to 450*
eDaddi:
Humidity sensors work by measuring the heat capacity of the medium. If the environment is 450F you will have to build your own. One TC measuring ambient, one measuring a hotplate with a known E heater.
The biggest problem I see is the inaccuracy of K-type sensors The head capacity of the medium would be lost in the noise of the sensor. I use K-types, but +-2F is acceptable, to calculate the heat capacity you would need sub degree accuracy.
Either a pulsed system, or a controlled flow orifice.
