high voltage analog pulse measurement
What happens when more than 5V appea on an Analog input pin?
does the ADC saturate at 1023?
does it wat around?
give me garbage?
or blow the arduino?
thanks
The ADC saturates at 1023. If you put more than about 5.6 V on the ADC pin, you may burn out the input pin, and perhaps the entire Arduino.
Thanks. that's my issue.
it's a given that that will happen. To simplify. I would have
one signal applied onto two Analog pins.
The first would have a divide by 4 and the second a divide by 16.
So the first would measure V between 0 and 20V, the second
between 0 and 80V.
But when 80V show up, the first ADC sees 20V. so would the
part burn out even if I put a large Resistor divider in it to stay
below the 20mA I read on this site the ADC can sink?
Is it good/ok/safe practice to put a diode in parallel to the lower
(dividing) Resistor to guarantee (sort of) that the voltage will
never be higher than 5? or 5.6 or even 4.7?
I need to measure and detect impulses and need as much of the
10 bit resolution the ADC can provide but also a higher dynamic range.
thanks a lot.
