Short version: Is there a digital pot that can drive around 10mA instead of the 2.5mA which seems to be standard? Ideally this would be a quad pot because I need 3 separate controls.
Long version:
I'm using 3 TLC5916 constant current drivers to drive the cathodes of a matrix of 24x16 LEDs; these chips use one resistor each to regulate current to the LEDs (e.g. 910 ohm gives each LED 20mA, 160 ohm gives each 120mA, etc.). The TI chip sheet is here:
I want to adjust overall brightness of the matrix via a photoresistor reading room light level. I thought I could do this with a MCP4451 i2c quad pot (http://ww1.microchip.com/downloads/en/DeviceDoc/22267A_MCP4431.pdf) but after Crossroad's advice on transistors I've been rereading the spec sheets and see that that chip only supports 2.5mA per pot. My multimeter says the TLC5916's pull about 7mA through their resistors, so that's not going to work.
I've been looking around and it seems that 2.5mA on a digital pot is standard. Does anybody know of one that can drive a (slightly) higher current?
Thanks
