Highly directional range finder
for one of my application Im finding small, but highly directional rangefinder. There is absolutely no need to be precise. I just need to know, if is something directly in front of my sensor (1 meter is enough). But it should be precise from view of angle - 5 cm on 1m distance is edgewise.
There are some requirements:
  • as small as possible
  • eye-safe (so any laser apllications are out of discussion)
Im not sure, if IR rangefinder is OK, because I think it is not too much directional (it takes reflection from large area, but I need to detect edges).
I would be appreciate for every idea.
Thanks,
Marek
My calculations make that an angle of 2.8 degrees, as you are ruling out a laser I can't see how you are going to do it with an arduino.
You could use a web cam with the language Processing (or anything else) and examine a small slice of the image for change and gate it with a wider beam distance sensor.
Thanks for idea! Unfortunately, this solution breaks requirement to small size. I have space approx 3x3 cm for this and no computation capacity (no real computer, just atmega).
I know it is really hard, maybe impossible in DIY environment. Im simply not experienced too much, so Im just asking others, if they know any solution...
OK best of luck but given your restraints I would say it is impossible.
How about an IR laser, no visible danger as the eye can't focus it.
