looks like yours is moved around a bit but you have to actually connect the buttons and LED to make them work. It was designed for prototyping (to give you more options) not plug and play.
So to make it work, you can jump the output to the connection but the power and ground must be connected and use a resistor for the LED if it doesn't have one. It may require soldering some jumper wires. I suggest 22 ga. Solid wire is fine.
