Hilfe bei obd bordcomputer
Hallo. Habe bei meinem Bordcomputer folgendes Problem in der config.h
Viellciht kann mir jemand helfen.
Arduino: 1.8.3 (Windows 10), Board: "Arduino Nano, ATmega328"
In file included from C:\Users\Doffl\Desktop\nanotimer\nanotimer.ino:14:0:
config.h:25: error: 'LCD_SSD1306' does not name a type
LCD_SSD1306 lcd;
C:\Users\Doffl\Desktop\nanotimer\nanotimer.ino: In member function 'virtual void COBDLogger::dataIdleLoop()':
nanotimer:179: error: 'lcd' was not declared in this scope
lcd.setFontSize(FONT_SIZE_SMALL);
nanotimer:179: error: 'FONT_SIZE_SMALL' was not declared in this scope
C:\Users\Doffl\Desktop\nanotimer\nanotimer.ino: In member function 'void COBDLogger::timerLoop()':
nanotimer:205: error: 'lcd' was not declared in this scope
lcd.setFontSize(FONT_SIZE_XLARGE);
nanotimer:205: error: 'FONT_SIZE_XLARGE' was not declared in this scope
nanotimer:244: error: 'FONT_SIZE_MEDIUM' was not declared in this scope
lcd.setFontSize(FONT_SIZE_MEDIUM);
nanotimer:254: error: 'FONT_SIZE_MEDIUM' was not declared in this scope
nanotimer:268: error: 'FONT_SIZE_SMALL' was not declared in this scope
nanotimer:294: error: 'FONT_SIZE_MEDIUM' was not declared in this scope
C:\Users\Doffl\Desktop\nanotimer\nanotimer.ino: In member function 'void COBDLogger::reconnect()':
nanotimer:307: error: 'lcd' was not declared in this scope
lcd.clear();
nanotimer:308: error: 'FONT_SIZE_MEDIUM' was not declared in this scope
C:\Users\Doffl\Desktop\nanotimer\nanotimer.ino: In member function 'void COBDLogger::showStates()':
nanotimer:326: error: 'lcd' was not declared in this scope
nanotimer:326: error: 'FONT_SIZE_SMALL' was not declared in this scope
C:\Users\Doffl\Desktop\nanotimer\nanotimer.ino: In member function 'void COBDLogger::showTimerResults()':
nanotimer:336: error: 'lcd' was not declared in this scope
nanotimer:336: error: 'FONT_SIZE_SMALL' was not declared in this scope
nanotimer:345: error: 'FONT_SIZE_MEDIUM' was not declared in this scope
C:\Users\Doffl\Desktop\nanotimer\nanotimer.ino: In member function 'void COBDLogger::initTimerScreen()':
nanotimer:374: error: 'lcd' was not declared in this scope
lcd.clear();
nanotimer:376: error: 'FONT_SIZE_SMALL' was not declared in this scope
C:\Users\Doffl\Desktop\nanotimer\nanotimer.ino: In function 'void setup()':
nanotimer:390: error: 'lcd' was not declared in this scope
lcd.begin();
nanotimer:391: error: 'FONT_SIZE_MEDIUM' was not declared in this scope
exit status 1
Dieser Bericht wäre detaillierter, wenn die Option
"Ausführliche Ausgabe während der Kompilierung"
in Datei -> Voreinstellungen aktiviert wäre.
Hallo,
noch- hast Du NUR- Probleme mit Deinem BordComputer.
Richtige Probleme können auftreten, wenn Du Deinen Code NICHT- in CodeTags(Editor </>) setzt.
Gruß und Spaß
Andreas
Es wäre auch sinnvoll, wenn Du uns Deinen Sketch mitteilst. Setze ihn bitte in Codetags (</> oben links im Editor)
Gruß Tommy
Das hier wäre die config.h dazu wo er mir den Fehler bringt.
Bei Choose LCD model here
LCD_SSD1306 lcd;
//LCD_SH1106 lcd;
//LCD_Null lcd;
Das LCD Modul LCD_SSD1306 lcd meckert er mir als Fehler an
//Config
#ifndef CONFIG_H_INCLUDED
#define CONFIG_H_INCLUDED
* Data logging/streaming out
#define ENABLE_DATA_OUT 0
#define ENABLE_DATA_LOG 0
#define USE_SOFTSERIAL 0
//this defines the format of log file
#define LOG_FORMAT FORMAT_CSV
* Choose SD pin here
#define SD_CS_PIN 10
* Choose LCD model here
LCD_SSD1306 lcd;
//LCD_SH1106 lcd;
//LCD_Null lcd;
* Other options
//#define OBD_MIN_INTERVAL 50 /* ms */
//#define DEBUG Serial
#define DEBUG_BAUDRATE 9600
#endif // CONFIG_H_INCLUDED
hier der Hauptcode etwas gekürzt damit er gepostet werden kann
#include <Arduino.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <SSD1306.h>
#include <OBD.h>
#include "config.h"
#if USE_SOFTSERIAL
#include <SoftwareSerial.h>
#endif
#include "datalogger.h"
private:
    void dataIdleLoop()
        if (state & STATE_SLEEPING) return;
        if (getState() == OBD_CONNECTED)
            return;
        // called while initializing
        char buf[10];
        unsigned int t = (millis() - startTime) / 1000;
        sprintf(buf, "%02u:%02u", t / 60, t % 60);
        lcd.setCursor(97, 7);
        lcd.print(buf);
    void timerLoop()
        uint32_t elapsed = millis() - startTime;
        uint16_t n;
#if !ENABLE_DATA_LOG
        uint32_t dataTime;
#endif
        int speed;
        if (!readPID(PID_SPEED, speed))
            return;
        dataTime = millis();
#if ENABLE_DATA_LOG
        logData(0x100 | PID_SPEED, speed);
        int rpm = 0;
        if (read(PID_RPM, rpm)) {
            logData(0x100 | PID_RPM, rpm);
#endif
        // estimate distance
        distance += (uint32_t)(speed + lastSpeed) * (dataTime - lastSpeedTime) / 2 / 3600;
        if (lastSpeed != speed) {
            lcd.setCursor(0, 4);
            lcd.printInt((unsigned int)speed % 1000, 3);
            lastSpeed = speed;
        lastSpeedTime = dataTime;
        if (stage == STAGE_WAIT_START) {
            if (speed > 0) {
                stage = STAGE_MEASURING;
                startTime = lastSpeedTime;
#if ENABLE_DATA_LOG
                uint32_t t = dataTime;
                dataTime = lastSpeedTime;
                logData(0x100 | PID_SPEED, lastSpeed);
                dataTime = t;
#endif
                lastSpeed = 0;
                distance = 0;
                memset(times, 0, sizeof(times));
                initTimerScreen();
        } else if (stage == STAGE_MEASURING) {
            // display elapsed time (mm:ss:mm)
            n = elapsed / 1000;
            if (n < 100) {
                lcd.setCursor(0, 0);
                lcd.printInt(n, 2);
                n = (elapsed % 1000) / 100;
                lcd.setCursor(32, 1);
                lcd.write('.');
                lcd.write('0' + n);
            if (times[2] == 0 && speed >= SPEED_THRESHOLD_3) {
                times[2] = elapsed / 100;
                stage = STAGE_IDLE;
                lcd.clear(0, 0, 128, 24);
                showTimerResults();
                lcd.print("DONE!");
            } else if (times[1] == 0 && speed >= SPEED_THRESHOLD_2) {
                times[1] = elapsed / 100;
                showTimerResults();
            } else if (times[0] == 0 && speed >= SPEED_THRESHOLD_1) {
                times[0] = elapsed / 100;
                showTimerResults();
            } else if (speed == 0) {
                // speed go back to 0
                stage = STAGE_IDLE;
            if (distance > 0) {
                lcd.setCursor(62, 6);
                if (distance >= 400) {
                    lcd.printInt(400, 3);
                    if (!times[3]) {
                        times[3] = elapsed / 100;
                        showTimerResults();
                    lcd.printInt(distance, 3);
#if ENABLE_DATA_LOG
            // log speed data
            // log additional data
            int rpm;
#endif
            if (speed == 0) {
                stage = STAGE_WAIT_START;
                initTimerScreen();
                lcd.println(" GET");
                lcd.println("READY");
    void reconnect()
#if ENABLE_DATA_LOG
        closeFile();
#endif
        lcd.clear();
        lcd.print("Reconnecting");
        startTime = millis();
        state &= ~STATE_OBD_READY;
        state |= STATE_SLEEPING;
        //digitalWrite(SD_CS_PIN, LOW);
        for (int i = 0; !init(); i++) {
            if (i == 10) lcd.clear();
        state &= ~STATE_SLEEPING;
        fileIndex++;
        setup();
    byte state;
    // screen layout related stuff
    void showStates()
        lcd.setCursor(0, 3);
        if (state & STATE_OBD_READY) {
            lcd.println("OBD connected!   ");
            lcd.println("Connecting OBD...");
    void showTimerResults()
        lcd.setCursor(56, 0);
        lcd.print(" 0~60:  --");
        lcd.setCursor(56, 2);
        lcd.print("0~100:  --");
        lcd.setCursor(56, 4);
        lcd.print("0~200:  --");
        lcd.setCursor(56, 6);
        lcd.print(" 400m:  --");
        char buf[8];
        if (times[0]) {
            sprintf(buf, "%2d.%1d", times[0] / 10, times[0] % 10);
            Serial.println(times[0]);
            lcd.setCursor(92, 0);
            lcd.print(buf);
        if (times[1]) {
            sprintf(buf, "%2d.%1d", times[1] / 10, times[1] % 10);
            Serial.println(buf);
            lcd.setCursor(92, 2);
            lcd.print(buf);
        if (times[2]) {
            sprintf(buf, "%2d.%1d", times[2] / 10, times[2] % 10);
            lcd.setCursor(92, 4);
            lcd.print(buf);
        if (times[3]) {
            sprintf(buf, "%2d.%1d", times[3] / 10, times[3] % 10);
            lcd.setCursor(92, 6);
            lcd.print(buf);
    void initTimerScreen()
        lcd.clear();
        showTimerResults();
        lcd.setCursor(24, 7);
        lcd.print("km/h");
static COBDLogger logger;
#ifdef DEBUG
    DEBUG.begin(DEBUG_BAUDRATE);
#endif
    lcd.begin();
    lcd.println("PerformanceBox");
    logger.begin();
#if ENABLE_DATA_LOG
    logger.initSender();
    logger.checkSD();
#endif
    logger.setup();
    logger.loop();
in den Libraries sind auch die
SSD1306.cpp
und
SSD1306.h
Hast du denn auch das gemacht, was in der Fehlermeldung steht ?
