Hilfe Bekomme die real time clock nicht ans laufen.
I2C Scanner
Scanning...
I2C device found at address 0x68 !
done
schilli84:
Doch uwe aber die haben alle den gleichen fehler
Das von mde110 geht leider auch nicht da kommt
sketch_jan14a:1: error: function definition does not declare parameters
In file included from sketch_jan14a.ino:4:
C:\Users\Dominic\Documents\Arduino\arduino-1.0.3\libraries\Wire/Wire.h:76: error: 'TwoWire' does not name a type
sketch_jan14a:6: error: 'DS1307new' does not name a type
sketch_jan14a:8: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:9: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:10: error: expected constructor, destructor, or type conversion before '(' token
sketch_jan14a:11: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:12: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:13: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:14: error: expected constructor, destructor, or type conversion before '(' token
sketch_jan14a:15: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:16: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:17: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:18: error: expected constructor, destructor, or type conversion before '.' token
sketch_jan14a:19: error: expected constructor, destructor, or type conversion before '.' token
So, habe mir jetzt extra die Arbeit gemacht und 1.0.3 neu entpackt und die Zip aus meinem Link in den Library Ordner entpackt.
Die Examples gehen. Ich vermute mal du hast an den Libs rumgespielt...
Also mach das bitte auch. Arduino 1.0.3 in ein neues Verzeichnis frisch entpacken.
Die DS1307new runterladen und in den Lib Ordner entpacken. Also da rein: arduino-1.0.3\libraries\DS1307new, sodass nacher auf jeden Fall diese Dateien vorhanden sind:
arduino-1.0.3\libraries\DS1307new\DS1307new.cpp
arduino-1.0.3\libraries\DS1307new\DS1307new.h
Dann kompiliere bitte das Example!
hey super leute sie geht jetzt.
nur wie kann ich sie einstellen??
Probiere doch mal ein bisschen rum anstatt gleich zu Fragen. So lernt man nichts...
So danke leute es hat geklappt uhr ist auch eingestelt.
morgen versuche ich mal die temperatur mit ins lcd zu bekommen.
und eine led zu bestimten zeiten ein und aus zu schalten.
mfg
