This is part of a motor speed calculator. THis same code tested on a teensy 3.2 has seen up to 50khz no issues, but on the nano i can't get it much farther than 13khz. This is a direct pin connection from the source sim arduino to the measuring nano/teensy.
_speed tops out at ~13K
Question: Am I doing anything wrong? Has anyone been able to read pulses at much higher frequencies?
The Arduino Nano uses a 16 MHz 8-bit microcontroller.
The Teensy 3.2 uses a 72 MHz ARM Cortex-M4 32-bit processor.
It is exactly what it is supposed to be.
The FreqCount library can probably measure into the Mega Hertz with an Arduino Nano.
donperry:
You have not posted enough of your code to be able to form any opinion. Post the whole program.
Use the digitalWriteFast library - it is a great deal faster than the standard digitalRead() / digitalWrite() but the I/O pins must be known at compile time.
Floating point calculations are very slow - avoid them if you can.
I can see no need to calculate the speed for every pulse. What is the speed value used for?
The 8 bit ATmegas even don't have hardware for integer division. Everybody can find out how much time takes the _speed calculation with 3 divisions.
For higher frequencies (above 10Hz) it's better to count pulses instead of their intervals. In either case perform calculations only when required, not normally inside an ISR.
I made a very fundamental mistake. I had declared the variable as int, instead of unsigned or even long. As soon as whatever I was doing with it reached 32,xxx it wrapped around.
Leave it here so other readers can benefit from your learning.
int triggerPin = 6;
long speed_now=0; //this was previously declared as int, causing an integer overflow, causing the nano to not read higher than what an integer would allow
long lastTime=0;
attachInterrupt(digitalPinToInterrupt(triggerPin), Count, FALLING);
Serial.print("Motor Speed: ");
Serial.print(speed_now);
Serial.println(" RPM");
void Count()
speed_now = 1.0 / (((micros() - lastTime) / 1000000.0) / 60.0);
lastTime = micros();
/* //The following was the old code that had the symptoms
* int triggerPin = 6;
int speed_now=0; //this was previously declared as int, causing an integer overflow, causing the nano to not read higher than what an integer would allow
int lastTime=0;
void Count()
Doing a floating point calculation takes a lot of processor power - way more than the digitalRead() or digitalWrite() calls. That's probably what slows you down most. It's really not a good idea to try and do this inside an ISR.
If you want to go really fast, connect your pulse input to the TC1 pin - for the 16-bit Timer1, and count pulses in hardware, you can get up to 8 MHz. Read the counter value at appropriate intervals (to have a good number of pulses but no risk of overflow) to calculate the frequency.
every now and then (a few times a second) you check how many pulses have been added over the past period, and calculate speed out of that.
If you calculate speed say ten times a second (enough for most practical purposes) you have lots of pulses. The half pulse you miss doesn't give a serious error. If it's for a human observer 2-3 times a second is enough, you can't read numbers much faster than that anyway.
