I'm working with Hitachi TX0705APAA5 TFT touch screen dispaly. I want to design a board to control and interfacing device to external system based on microcontroller or DPS.
I thought to
set IM0, IM2, IM3 pin of TFT device, to 111 (4 wire SPI mode)
use ILI9486L (or similar) to drive graphic interface in TX0705APAA5
connect the IC's out DB[17:0] to digital input DB[17:0] (pin 10 - 27)
I should connect Hitachi TFT with 39 way flat cable, so I have found out this Flexible Printed Circuit Connectors:
I would be interested in hearing your views on these matters.
It appears to be a 240x320 panel for a mobile phone.
If you want help, please provide a link to a datasheet.
Yes, if you have access to the IM# pins, you can use whichever interface you want.
4-wire SPI is a wise choice. Remember that 3.3V panels require level converters for the logic.
By the time that you have wired level converters, ribbon connectors, ... to the Arduino it would have been easier to plug a ready-made Shield onto your Uno, Mega, Zero, Due, ...
