I can't tell you how accurate that site is (it doesn't seem to be related to the producer of the servo).
You cannot do 2 things simultaneously with an Arduino.
But you can do things very fast one after another so that it seems to happen at the same time.
Learn a bit about how servos are controlled, and find out whether or not it would be needed to do things simultaneously.
Keep in mind that a servo needs to overcome some momentum, leading to a delay of sorts.
dovidu:
i know most standard sized servos rotate 180deg via arduino.
Wrong, so wrong.... Most have somewhere around 120 to 150 degree motion, which
is perfectly adequate for their role in RC planes as control-surface actuators.
