HiTechnic Motor Controller
Hello. I was wondering if it would be possible to have one or many HiTechnic Motor Controllers interfaced with Arduino. They are I2C, but I don't know anything about that. I am using UNO R3.
What's a Tetrix Motor Controller? Got a link?
Whoops, meant to say HiTechnic DC Motor Controller. Classroom Solutions for STEM and STEAM | LEGO® Education
Edit: I think I found a PDF that would be useful: Classroom Solutions for STEM and STEAM | LEGO® Education
So for the code, I know I need to use the Wire library for I2C communications. Basically, I would be sending motor 1, or address 02, a value for the motor speed, right? I know in Labview for FTC, the motor values go from 0-255, so I don't know if they are the same here or not.
And also, how would I wire it to my Arduino? I was thinking of just stripping the wires, or using this breakout: Bricktronics Breakout Board :: Wayne and Layne Store
Basically, I don't know exactly how to approach this project, but I have ideas how.
Edit: I found a website with how the wires are layed out in the connector. http://www.mindsensors.com/index.php?module=pagemaster&PAGE_user_op=view_page&PAGE_id=136
I have an Uno R1 & R3, so SDA goes to A4, and SCL goes to A5, correct? And of course, 5V to 5V, and GND to GND.
Also found another picture with what the 6th lead is, and color codes:
Reading the spec sheet for the controller, the range for the speed goes from -100 to 100. 45H and 47H are power for each motor. So here is how I think I would write the code:
#include <Wire.h>
byte speed = 100;
  Wire.begin(); // join i2c bus
  Wire.beginTransmission(0x02); // transmit to device #44 (0x2c)
                              // device address is specified in datasheet
  Wire.write(speed);             // sends value byte
  Wire.endTransmission();     // stop transmitting
That should send 100 to address 0x02 every half second, but how does it know to set motor one to 100? Do I have to send a string of data?
