Hi guys,
I've wasted many days with a problem with the serial port.
I'm using Mega2560, MAX232 (DB9) and WAVECOM Fastrack GSM modem (DB15).
My MAX232 connects fine with PC-RS232. I open two TeraTerm windows (one connected to Arduino, another one to PC serial port) and no problems sending and receiving.
No problems connecting PC to modem with original cable (DB9 to DB15).
I have an old 56K modem. I tried the MAX232 and runs smoothly.
But ... I can't connect the MAX232 to the GSM modem.
To connect MAX232 to GSM-modem I used a three-wire cable TX/RX (2/2), RX/TX (3/6) and GND/GND (5/9). Where (X = DB9/Y = DB15).
I found a clue. I could connect from PC to modem using 4 wires. The fourth wire going from RTS (DB9 pin 7) to CTS (DB15 pin 11).
I discovered I can disable flow control on modem. The command is AT+IFC=0,0. It did not work.
I've also tried to tie CTS and RTS signals on modem. It did not work.
By the way, also tied DCD, DTR and DTS.
But still no response.
How I can have the "fourth wire" (CTS to RTS) from MAX232?
Any ideas? THX!
