Hlaf-duplex - what am I doing wrong?
I am using two arduino pro minis. I need to get reliable MAX485 comms through them. For this I am using gammon's RS485_protocol library:
I can get reliable one way communication. I can even get half of the conversation:
Master query
Slave receipt
Slave response
Master fails to receive
I must be doing something wrong with the half-duplex. I've established that it's not hardware, all the pieces work individually; see code samples below.
Does anyone have working half-duplex comms through a MAX485 chip that I can crib? This is driving me NUTS!
Test send:
#include <AltSoftSerial.h>
#include <RS485_protocol.h>
AltSoftSerial rs485;
byte msg[3] = {'h', 'E', 'L'};
// callback routine'
void fWrite (const byte what)
  rs485.write (what);
int fAvailable ()
  return rs485.available ();
int fRead ()
  return rs485.read ();
  Serial.println("AltSoftSerial Send Test Begin");
  rs485.begin(9600);
  digitalWrite(13,HIGH);
  delayMicroseconds(500);
  sendMsg (fWrite, msg, sizeof msg);
  rs485.flush();
  digitalWrite(13, LOW);
Test receipt:
  rs485.write (what);
int fAvailable ()
int fRead ()
  Serial.println("AltSoftSerial Receive Test Begin");
  rs485.begin(9600);
  char c;
  byte buf[32];
  c=0;
  buf [0] = 5;
  int i,j;
  if(i=recvMsg(fAvailable, fRead, buf, sizeof buf,900))
    for (j = 0 ; j < i; j++) Serial.println(buf[j]);
  else Serial.println("nnothing receivd");
Now put it together - first the master:
// callback routines
  rs485.write (what);
  //    rs485.flush();
int fAvailable ()
int fRead ()
  rs485.begin (9600);
  pinMode(rs485XmitPin, OUTPUT);
  digitalWrite(rs485XmitPin, LOW);
}  // end of setup
byte msg [1];
byte buf [32];
  byte i;
    Serial.print("querying slave ");
    Serial.println(i);
    msg [0] = 5;
    digitalWrite(rs485XmitPin, HIGH);
    sendMsg (fWrite, msg, 1);
    rs485.flush();
//   this never succeeds
//   there is never any data in the serial buffer
    if (!recvMsg (fAvailable, fRead, buf, sizeof buf, 1000)) {
      Serial.print("no response from Slave ");
      Serial.println(i);
The slave does send out the data; I can receive it with the simpler test above. It's only when the master sends the query that the subsequent read fails.
Slave
  rs485.write (what);
int fAvailable ()
int fRead ()
  // initialize serial communication at 9600 bits per second:
  rs485.begin(9600);
  address = 5;
  byte buf [32];
// this succeeds
  if (recvMsg (fAvailable, fRead, buf, 19))
    if (buf [0] != address) {
      Serial.print(buf[0]);
      Serial.println(" not mine, skipping.");
    else {
      Serial.println("got a query");
      buf[0]=23;
      sendMsg (fWrite, buf, 1);
      rs485.flush();
      Serial.println("Sent response");
  else {
    Serial.println("No query received");
}  // end if something received
Try inserting the line
delay(1);
before this line:
It's in the example code of Nick Gammon too and gives the master time to prepare for receiving.
But I don't see the reason for the delayMicroseconds(500) in your code.
