Hello,
I’d like to ask for you guidance in my project. My goal is to detect iBeacons (or beacons in general). My setup is:
- Arduino UNO R3 board
- HM-10 bluetooth module (true HM-10)
I managed to wire above correctly so that beacons are detected however I have some issues with the data that i receive from HM-10 dongle. The connection is done via Software Serial and the issue is that it seems that the messages that i get are somehow cut - like transmission is interrupted. Here is the code that I use:
#include <SPI.h>
#include <SoftwareSerial.h>
String inputTXT;
SoftwareSerial mySerial(5, 6); // RX, TX
mySerial.begin(9600);
//setup
mySerial.write("AT");
delay(100);
mySerial.write("AT+ROLE1");
delay(100);
mySerial.write("AT+IMME1");
delay(100);
mySerial.write("AT+RESET");
delay(50);
delay(3000);
mySerial.write("AT+DISI?");
if (mySerial.available()) {
inputTXT = mySerial.readString();
Serial.println(inputTXT);
inputTXT = "";
Normally the response is:
OK+DISISOK+DISC:4C000215:E9780B60F7194ADAA0BE5A98BAA5C976:04D2162EBF:685FCA5B1F45:-057OK+DISCE
However sometimes the code is cut and shows:
OK+DISISOK+DISC:4C000215:B9407F30F5F8466EAFF925556B57FE6D:40243065A5:FB
The situation is getting worse when I have more than 3 beacons around. If I have 6-7 sometimes the data received from HM-10 is totally scrambled and there is no response… My project requires to handle multiple number of beacons changing quickly in time so reliable info on discovered beacons is a key.
I appreciate any ideas and/or best practices here
Thanks,
Robert
