Hello everyone. I bought the HM-10 BLE module from Amazon and using this link found in the item's description, I managed to get the module talking to my iPhone, but it's not doing everything I need it to. The zip file includes the datasheet for the module, as well as Apple's ANCS specification document and a helpful text file. Here's a copy of the text file
HMSoft verion V524 added ANCS support (not include HMSensor version)
1. How to open ANCS function
1.1 Please read apple notification ducument first.
1.2 Send AT+TYPE3 command change to AUTH and BOND mode.
1.3 Send AT+ANCS1 command to open ANCS.
1.4 Send AT+PASS[para1] command to set passcode. Default passcode is "000000"
1.5 Send AT+RESET to restart module.
Now you can use LightBlue or our software to scan and made a connect with module.
iOS will ask you input passcode. please input your passcode value.
If all is okay, you should receive AT+ANCS[para1] command from module UART.
2. About AT+ANCS[para1] command
AT+ANCSN: module open Notification Source SUCCESSED.
AT+ANCSC: module open Control Point SUCCESSED.
AT+ANCSD: module open Data Source SUCCESSED.
3. Get ANCS notification information
When iOS notification center has an change (such as call, email, shortmessage)
Module will output AT+ANCS8[para2] command through UART.
4. About AT+ANCS8[para2] command.
Format such as : AT+ANCS801012345
8: The length of the para1.
0: EventID.
EventIDNotificationAdded = 0,
EventIDNotificationModified = 1,
EventIDNotificationRemoved = 2,
Reserved EventID values = 3¨C255
1: CategoryID.
CategoryIDOther = 0,
CategoryIDIncomingCall = 1,
CategoryIDMissedCall = 2,
CategoryIDVoicemail = 3,
CategoryIDSocial = 4,
CategoryIDSchedule = 5,
CategoryIDEmail = 6,
CategoryIDNews = 7,
CategoryIDHealthAndFitness = 8,
CategoryIDBusinessAndFinance = 9,
CategoryIDLocation = 10,
CategoryIDEntertainment = 11,
Reserved CategoryID values = 12¨C255
01: CategoryCount
The current number of active iOS notifications in the given category.
For example, if two unread emails are sitting in a user¡¯s email inbox,
and a new email is pushed to the user¡¯s iOS device, the value of CategoryCount is 3.
2345: NotificationUID
A 32-bit numerical value that is the unique identifier (UID) for the iOS notification.
This value can be used as a handle in commands sent to the Control Point characteristic
to retrieve more information about the iOS notification.
5. Get Notification Attributes
AT+ANCS[para1][para2][para3]
Format such as: AT+ANCS2345100
para1: NotificationUID.
Para2: NotificationAttributeID
NotificationAttributeIDAppIdentifier = 0,
NotificationAttributeIDTitle = 1, (Needs to be followed by a 2-bytes max length parameter)
NotificationAttributeIDSubtitle = 2, (Needs to be followed by a 2-bytes max length parameter)
NotificationAttributeIDMessage = 3, (Needs to be followed by a 2-bytes max length parameter)
NotificationAttributeIDMessageSize = 4,
NotificationAttributeIDDate = 5,
Reserved NotificationAttributeID values = 6¨C255
Para3: max length parameter
If para2 value is 0, 4, 5, para3 must set to "00"
if para2 value is 1, 2, 3, you need setup a number.
6. Aoubt Get Notification Attributes Response
AT+ANCSW: Send request SUCCESSED.
AT+ANCS[para1]:
para1 value is 0x00 ~ 0x14.
Mean the next package length you need to receive.
[........]: The byte array you need to receive.
Show in apple Notification document Figure 2-6. (page 9)
After you receive AT+ANCSW, you may receive AT+ANCS[para1] many times. until the Fingure 2-6 package is completed.
7. How to remove ANCS.
7.1 Remove bond information from iOS.
7.2 Execute AT+ERASE remove module bond information.
7.3 Execute AT+ANCS0 close module ANCS function.
7.4 Execute AT+RESET to restart module.
ANCS is easy to use, you dont need write any iOS code. iOS will manage the bluetooth link and push the message to module.
If you have any good idea, please mail me: guocg@jnhuamao.cn.
My english is not good, I hope you can made this document perfect.
Thank you.
HMSoft
www.jnhuamao.cn
www.huamaosoft.com
2014-03-08
So as seen above, sending a Notification Attribute request requires the AT+ANCS part first, followed by the four digit Unique ID, the single digit Attribute ID, and finally the double digit maximum length parameter. The maximum length parameter is also interpreted as a HEX value by the iPhone.
Referencing Apple's ANCS developer document found here and in the zip file, a single digit Command ID is supposed to precede the four digit Unique ID. This is first seen in figure 2-3. This is the part I'm having trouble with, as I would like to perform a Notification Action, which requires setting the Command ID to 2. The format for performing a Notification Action as seen in Apple's document is the single digit Command ID, which should be 2, followed by the four digit Unique ID, and then the single digit Action ID.
I tried just sending that information with the "AT+ANCS" part before it, but it didn't work. The Apple ANCS document found in the zip file included with the HM-10 module isn't the most recent version of it, so it's missing the Perform Notification Action section. A little over a week ago, I sent an email to the email address found near the bottom of the text document asking how to use the Perform Notification Action and I never got a reply. So I was wondering if anyone here knew if it was possible to use the Perform Notification Action with the HM-10 BLE module.
Thank you!
