[HM-10] Need help in simple coding!
Hello,
I have connected BT module to my Arduino Uno, everything work, but I want to change the code:
#include <SoftwareSerial.h>;
int TX_PIN = 10;
int RX_PIN = 11;
SoftwareSerial bluetooth(TX_PIN, RX_PIN);
String receivedBluetoothString = "";
int led = 12;
  bluetooth.begin(9600);
  pinMode(led, OUTPUT);
  while (bluetooth.available() > 0) {
    char receivedBluetoothChar = bluetooth.read();
    receivedBluetoothString += receivedBluetoothChar;
    if (receivedBluetoothChar == '\n') {
      if (receivedBluetoothString.toInt() == 1111) {
And after Arduino (receivedBluetoothString.toInt() == 1111) should set pin X to HIGH, but after i send the same “1111” code the pin should go LOW. I tried coding with boolean ang long function but still it doesn’t work.
avik111:
Hello,
int TX_PIN = 10;
int RX_PIN = 11;
String receivedBluetoothString = “”;
int led = 12;
if (receivedBluetoothChar == ‘\n’) {
And after Arduino (receivedBluetoothString.toInt() == 1111) should set pin X to HIGH, but after i send the same "1111" code the pin should go LOW. I tried coding with boolean ang long function but still it doesn't work.
Try this:
bool ledStage=false; // led initially is off
#define led 13  //  pin number that a LED is connected to
void setup(){
pinMode(led,OUTPUT);
void loop(){
    ledState = !ledState; // ledState will alternate between HIGH and LOW, LOW=!HIGH, HIGH=!LOW
    digitalWrite(led,ledState);
Chuck.
@chucktodd
Thank you very much, works flawlessly!
Regards, Lucas
