HM-10 - Reading Data
Please help !!
I am currently making a plant monitor system for college. I am fairly new to programming and could use some help. So far, I have successfully amalgamated serval programs into a complete program that can monitor lux levels, display heat and humidity on a LCD screen and a soil sensor that will determine if the soil is dry and turn on a buzzer as a warning. the code is below:
// light
int sensorPin = A0; // select the input pin for the potentiometer
float rawRange = 1024; // 3.3v
float logRange = 5.0; // 3.3v = 10^5 lux
//heat
#include <dht.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
dht DHT;
#define DHT11_PIN 7
// soil sensor
int led_pin = 9;
int sensor_pin = 8;
//light
analogReference(EXTERNAL); //
Serial.println("Adafruit Analog Light Sensor Test");
//heat
lcd.begin(16, 2);
//soil
pinMode(led_pin, OUTPUT);
pinMode(sensor_pin, INPUT);
// read the raw value from the sensor:
// light
int rawValue = analogRead(sensorPin);
Serial.print("Raw = ");
Serial.print(rawValue);
Serial.print(" - Lux = ");
Serial.println(RawToLux(rawValue));
//heat
int chk = DHT.read11(DHT11_PIN);
lcd.setCursor(0, 0);
lcd.print("Temp: ");
lcd.print(DHT.temperature);
lcd.print((char)223);
lcd.print("C");
lcd.setCursor(0, 1);
lcd.print("Humidity: ");
lcd.print(DHT.humidity);
lcd.print("%");
//soil
if(digitalRead(sensor_pin) == HIGH)
digitalWrite(led_pin, HIGH);
digitalWrite(led_pin, LOW);
float RawToLux(int raw)
float logLux = raw * logRange / rawRange;
return pow(10, logLux);
The problem i now have is i would like to receive the lux levels that are printed on the serial monitor over Bluetooth. I have purchased a HM-10 module, which after some research can connect to an iPhone. However, i am unsure on what i need to do (connection wise, additional programming and an app to use) to make this work. Can anyone with some expertise please assist.
Many thanks Tom
http://www.martyncurrey.com/hm-10-bluetooth-4ble-modules/
From reading that link it looks like I have a hm-10 breakout module. I have found that I can connect using the light blue app. Connecting the Vcc to 3.3v and ground.. also with my digital I/O connected. However, I cannot seem to communicate anything between the two (app and Arduino). Some videos I have seen shows a “connected” state at the bottom of the Arduino program. I do not have this. Also, if I type AT in the serial monitor while connected nothing happens. Has anyone actually connected an iPhone to Arduino Uno using a HM-10. If so, what app did you use ? Do I have to do awaken the module or by connecting to my iPhone does that mean it’s already awake ? .. any help would be much appreciated
You can try contacting Martyn.
I have neither an iPhone or a HM-10.
With the regular Bluetooth, you have to pair the module and the Android smartphone.
Thank you for your input. There must be a way, this is just my first time and unfamiliar to it
