I have connected an HM-11 bluetooth module to my Arduino Micro as follows :
Arduino - HM-11
0 (TX) - RX
1 (RX) - TX
GND - GND
VCC - 3V3
2 things :
I use the following code on my arduino to test the AT commands with no luck.
Tried setting with NL & CR and no line ending. But still no answer from my HM-11
#include <SoftwareSerial.h>
SoftwareSerial BTSerial(1, 0); //RX|TX
void setup(){
BTSerial.begin(9600); // default baud rate
while(!Serial); //if it is an Arduino Micro
Serial.println("AT commands: ");
void loop(){
//read from the HM-10 and print in the Serial
if(BTSerial.available())
Serial.write(BTSerial.read());
//read from the Serial and print to the HM-10
if(Serial.available())
BTSerial.write(Serial.read());
second problem :
On my PC I see the HM-11 module and I can connect to it (pair) but my PC doesn’t createextra COM ports, so there is no way for me to communicate with the HM-11.
Someone can help me out a little bit?
On the Arduino do not use hardware serial, use software serial or AltSoftSerial. Have a look at HM-10 Bluetooth 4/BLE Modules.
When connecting to a PC pairing doesn't create a connection. You then need to use the Bluetooth software on the PC to make the connection and get a COM port.
MartynC:
thanks I'll check the website
Which Bluetooth software do you mean to make a connection?
It does work now with softSerial on Pin 8 & 9 with following commands :
http://wiki.seeed.cc/Bluetooth_V4.0_HM_11_BLE_Module/
stevennoppe:
On my workstation I have a BlueSoleil Bluetooth dongle and I use the software that came with it to scan and connect to Bluetooth devices.
I've installed the BlueSoleil Bluetooth software and although it sees my HM-11, it doesn't want to add and attach new COM ports.
Could this be because I do not have a dongle from Blue Soleil and I use my on-board Bluetooth?
I've read somewhere that it would be better to buy an extra HM-11 and connect this one to my PC through USB and let the 2 HM-11 communicate with eachother?
