hm
Seems like a reasonable set of components. Check the pin usage of the WiFi and GPS logger boards to make sure they don't conflict.
The link you posted for the diamondback has a schematic for the board that appears to show the wifi module connected to the SPI pins on the Atmega.
Looks like the WiFi module has the SS signal on Pin 10 but the SD card on the GPS logging shield also uses Pin10 for SS. Perhaps an external SD adapter and GPS module would avoid the conflict.
It should be possible to cut the trace and jumper it to another pin.
johnwasser:
[quote author=Max Diamond link=topic=96263.msg723242#msg723242 date=1331588339]
Hmmm would it be possible to modify the SD card on the logging shield to use a different pin?
[/quote]
Even easier, clip the D10 pin off the shield and connect a jumper from the shield's D10 socket to the D9 or D8 socket (assuming one of them is not used).
Hi Diamond, wanted to check how your project is going. I'm looking at a similar application (quadcopter related) and was wondering if you got it to work and if you might be willing to share it. Thanks! Peter
