I Have a product using a HC05.
But to make it work with an iphone i need a BLE device.
So because of the size and formfactor i bought several HM10 and CC41 and HM11 Bluetooth shields.
to try which one is the best for all platforms. (Android Windows and IOS)
So now i connected the BLE shield to my Arduino (Mega) with the board and 3,3v to 5v converter and one without the board directly to a Due.
I can send commands to the shield and the shield is answering.
So i See the menu etc.
- Command Description *
- AT Check if the command terminal work normally *
- AT+RESET Software reboot *
- AT+VERSION Get firmware, bluetooth, HCI and LMP version *
- AT+HELP List all the commands *
- AT+NAME Get/Set local device name *
- AT+PIN Get/Set pin code for pairing *
- AT+PASS Get/Set pin code for pairing *
- AT+BAUD Get/Set baud rate *
- AT+LADDR Get local bluetooth address *
- AT+ADDR Get local bluetooth address *
- AT+DEFAULT Restore factory default *
- AT+RENEW Restore factory default *
- AT+STATE Get current state *
- AT+PWRM Get/Set power on mode(low power) *
- AT+POWE Get/Set RF transmit power *
- AT+SLEEP Sleep mode *
- AT+ROLE Get/Set current role. *
- AT+PARI Get/Set UART parity bit. *
- AT+STOP Get/Set UART stop bit. *
- AT+START System start working. *
- AT+IMME System wait for command when power on. *
- AT+IBEA Switch iBeacon mode. *
- AT+IBE0 Set iBeacon UUID 0. *
- AT+IBE1 Set iBeacon UUID 1. *
- AT+IBE2 Set iBeacon UUID 2. *
- AT+IBE3 Set iBeacon UUID 3. *
- AT+MARJ Set iBeacon MARJ . *
- AT+MINO Set iBeacon MINO . *
- AT+MEA Set iBeacon MEA . *
- AT+NOTI Notify connection event . *
- AT+UUID Get/Set system SERVER_UUID . *
- AT+CHAR Get/Set system CHAR_UUID . *
- Note: (M) = The command support slave mode only. *
- For more information, please visit http://www.bolutek.com *
- Copyright@2013 www.bolutek.com. All rights reserved. *
So that part is working. every BLE sample i download for android or ios let me connect to the shield (led stops flashing and stays on) but i don't see any data comming in.
I tried it with my Logic analyzer and the shield isn't sending any data through the TX and RX ports.
Any idea.
I tested four of them and none respond.
Kind regards
Johan
