HMC 5883l
I am using a HMC-5883l GY-20 chip to try and make a basic compass, to use in a project.
I have tried using the example code on arduino IDE.
HMC5883L Triple Axis Digital Compass. Simple Example.
Read more: /dev/jarzebski: 3-osiowy magnetometr HMC5883L
GIT: GitHub - jarzebski/Arduino-HMC5883L: HMC5883L Triple Axis Digital Compass Arduino Library
Web: http://www.jarzebski.pl
(c) 2014 by Korneliusz Jarzebski
#include <Wire.h>
#include <HMC5883L.h>
HMC5883L compass;
// Initialize HMC5883L
Serial.println("Initialize HMC5883L");
while (!compass.begin())
Serial.println("Could not find a valid HMC5883L sensor, check wiring!");
// Set measurement range
// +/- 0.88 Ga: HMC5883L_RANGE_0_88GA
// +/- 1.30 Ga: HMC5883L_RANGE_1_3GA (default)
// +/- 1.90 Ga: HMC5883L_RANGE_1_9GA
// +/- 2.50 Ga: HMC5883L_RANGE_2_5GA
// +/- 4.00 Ga: HMC5883L_RANGE_4GA
// +/- 4.70 Ga: HMC5883L_RANGE_4_7GA
// +/- 5.60 Ga: HMC5883L_RANGE_5_6GA
// +/- 8.10 Ga: HMC5883L_RANGE_8_1GA
compass.setRange(HMC5883L_RANGE_1_3GA);
// Set measurement mode
// Idle mode: HMC5883L_IDLE
// Single-Measurement: HMC5883L_SINGLE
// Continuous-Measurement: HMC5883L_CONTINOUS (default)
compass.setMeasurementMode(HMC5883L_CONTINOUS);
// Set data rate
// 0.75Hz: HMC5883L_DATARATE_0_75HZ
// 1.50Hz: HMC5883L_DATARATE_1_5HZ
// 3.00Hz: HMC5883L_DATARATE_3HZ
// 7.50Hz: HMC5883L_DATARATE_7_50HZ
// 15.00Hz: HMC5883L_DATARATE_15HZ (default)
// 30.00Hz: HMC5883L_DATARATE_30HZ
// 75.00Hz: HMC5883L_DATARATE_75HZ
compass.setDataRate(HMC5883L_DATARATE_15HZ);
// Set number of samples averaged
// 1 sample: HMC5883L_SAMPLES_1 (default)
// 2 samples: HMC5883L_SAMPLES_2
// 4 samples: HMC5883L_SAMPLES_4
// 8 samples: HMC5883L_SAMPLES_8
compass.setSamples(HMC5883L_SAMPLES_1);
// Check settings
checkSettings();
void checkSettings()
Serial.print("Selected range: ");
switch (compass.getRange())
case HMC5883L_RANGE_0_88GA: Serial.println("0.88 Ga"); break;
case HMC5883L_RANGE_1_3GA: Serial.println("1.3 Ga"); break;
case HMC5883L_RANGE_1_9GA: Serial.println("1.9 Ga"); break;
case HMC5883L_RANGE_2_5GA: Serial.println("2.5 Ga"); break;
case HMC5883L_RANGE_4GA: Serial.println("4 Ga"); break;
case HMC5883L_RANGE_4_7GA: Serial.println("4.7 Ga"); break;
case HMC5883L_RANGE_5_6GA: Serial.println("5.6 Ga"); break;
case HMC5883L_RANGE_8_1GA: Serial.println("8.1 Ga"); break;
default: Serial.println("Bad range!");
Serial.print("Selected Measurement Mode: ");
switch (compass.getMeasurementMode())
case HMC5883L_IDLE: Serial.println("Idle mode"); break;
case HMC5883L_SINGLE: Serial.println("Single-Measurement"); break;
case HMC5883L_CONTINOUS: Serial.println("Continuous-Measurement"); break;
default: Serial.println("Bad mode!");
Serial.print("Selected Data Rate: ");
switch (compass.getDataRate())
case HMC5883L_DATARATE_0_75_HZ: Serial.println("0.75 Hz"); break;
case HMC5883L_DATARATE_1_5HZ: Serial.println("1.5 Hz"); break;
case HMC5883L_DATARATE_3HZ: Serial.println("3 Hz"); break;
case HMC5883L_DATARATE_7_5HZ: Serial.println("7.5 Hz"); break;
case HMC5883L_DATARATE_15HZ: Serial.println("15 Hz"); break;
case HMC5883L_DATARATE_30HZ: Serial.println("30 Hz"); break;
case HMC5883L_DATARATE_75HZ: Serial.println("75 Hz"); break;
default: Serial.println("Bad data rate!");
Serial.print("Selected number of samples: ");
switch (compass.getSamples())
case HMC5883L_SAMPLES_1: Serial.println("1"); break;
case HMC5883L_SAMPLES_2: Serial.println("2"); break;
case HMC5883L_SAMPLES_4: Serial.println("4"); break;
case HMC5883L_SAMPLES_8: Serial.println("8"); break;
default: Serial.println("Bad number of samples!");
Vector raw = compass.readRaw();
Vector norm = compass.readNormalize();
Serial.print(" Xraw = ");
Serial.print(raw.XAxis);
Serial.print(" Yraw = ");
Serial.print(raw.YAxis);
Serial.print(" Zraw = ");
Serial.print(raw.ZAxis);
Serial.print(" Xnorm = ");
Serial.print(norm.XAxis);
Serial.print(" Ynorm = ");
Serial.print(norm.YAxis);
Serial.print(" ZNorm = ");
Serial.print(norm.ZAxis);
delay(100);
This error comes up.
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't set com-state for "\.\COM4"
avrdude done. Thank you.
I have tried changing the baud rate and the COM port, but it doesn't work.
Any help would be greatly appreciated.
Your Arduino is not on COM4.
I have tried changing the COM port but it doesn't help
Sorry, just realised there is a mistake in my original post. It is the hmc5583l gy271
What does your Device Manager show?
