HMC5883L can't read raw data
Sensor wired to a Mega2560. Compiles with no errors. All I see is two numbers that do not change even when i move the compass.
I am just looking to see some raw (un- calibrated) readings, just to get a feel for the sensor and its quirks.
I took the example code and just extracted what i wanted to see (even if not perfect).
Any help is much appreciated!
// Reference the I2C Library
#include <Wire.h>
// Reference the HMC5883L Compass Library
#include <HMC5883L.h>
//#include "Streaming.h"
// Store our compass as a variable.
HMC5883L compass;
// Record any errors that may occur in the compass.
int error = 0;
MagnetometerRaw raw;
// Out setup routine, here we will configure the microcontroller and compass.
   compass.initCompass() ;
   compass.getCompass();
   // Initialize the serial port.
   delay(2000);
   Serial.println("Starting the I2C interface.");
   Wire.begin(); // Start the I2C interface.
   Serial.println("Constructing new HMC5883L");
   Serial.println("Setting scale to +/- 1.3 Ga");
   error = compass.setScale(1.3); // Set the scale of the compass.
   if(error != 0) // If there is an error, print it out.
     Serial.println(compass.getErrorText(error));
   Serial.println("Setting measurement mode to continous.");
   error = compass.setMeasurementMode(MEASUREMENT_CONTINUOUS); // Set the measurement mode to Continuous
//**************************************************   L   O   O   P   **********************************************************
// Our main program loop.
   // Retrive the raw values from the compass (not scaled).
   MagnetometerRaw  raw = compass.readRawAxis();
   Serial.print(raw.YAxis);
   Serial.print( F( "   "  ) ) ;
   Serial.println(raw.YAxis);
   delay(100) ;
The HMC5883L has not been manufactured for several years. You may have a QMC5883 instead (sometimes they are mislabeled as HMC5883).
There is a different library for that, and also, the I2C address is different, which the I2C address scanner program will report.
The underside of the sensor says "GY-273". I will try to find a QMC5883 lib.
Bingo! I downloaded the QMC lib and works just fine! Thank you (everyone) for all the help!!
