Hello,
I am working on a project that has a Heltec esp32 v2 with a compass point to another at a separate location. The receiving end has a compass because often times when this is in use the person will not be moving but it is still necessary to know the heading of the device. Without the compass code, The Loop section will run. Once I add in the code for the compass, it will run until it hits that portion of the code and then stop. If I remove all the other code and just run the code from the compass, It will run as well. Any insight as to what is freezing up?
#include <TinyGPS.h>
#include <Wire.h>
#include <HMC5883L.h>
#include "heltec.h"
#define BAND 433E6 //you can set band here directly,e.g. 868E6,915E6
String rssi = "RSSI --";
String packSize = "--";
String packet, slat, slon;
String pkt2;
int pksize;
float tlati, tlon;
float clat, clon, cbearing, bearing;
int comma1 = 0, comma2 = 0, salti = 0;
HMC5883L compass;
TinyGPS gps;
float flat, flon;
unsigned long age, date, chars;
int year;
byte month, day, hour, minute, second, hundredths;
char sz[32];
bool newData= false;
HardwareSerial GPS_Serial(2);
void cbk(int packetSize) {
packet ="";
pkt2 = "";
packSize = String(packetSize,DEC);
pksize = packetSize;
for (int i = 0; i < packetSize; i++) { packet += (char) LoRa.read();
delay(100);
pkt2 = packet;
Serial.println(pkt2);
parsedata();
void parsedata(){
comma1 = 0;
comma2 = 0;
slat="";
slon = "";
for (int x = 0; pkt2[x]!=','; x++){
slat+=pkt2[x];
comma1 = x;
for (int i = ((comma1)+2); pkt2[i]!=','; i++){
slon += pkt2[i];
comma2 = i;
tlon = (slon.toFloat());
tlati = (slat.toFloat());
Serial.println(tlon,6);
Serial.println(tlati,6);
Serial.println("Initialize HMC5883L");
while (!compass.begin())
Serial.println("Could not find a valid HMC5883L sensor, check wiring!");
// Set measurement range
compass.setRange(HMC5883L_RANGE_1_3GA);
// Set measurement mode
compass.setMeasurementMode(HMC5883L_CONTINOUS);
// Set data rate
compass.setDataRate(HMC5883L_DATARATE_30HZ);
// Set number of samples averaged
compass.setSamples(HMC5883L_SAMPLES_8);
// Set calibration offset. See HMC5883L_calibration.ino
compass.setOffset(0, 0);
Heltec.begin(true /*DisplayEnable Enable*/, true /*Heltec.Heltec.Heltec.LoRa Disable*/, true /*Serial Enable*/, true /*PABOOST Enable*/, BAND /*long BAND*/);
Heltec.display->init();
Heltec.display->flipScreenVertically();
Heltec.display->setFont(ArialMT_Plain_10);
Heltec.display->clear();
Heltec.display->drawString(0 , 15 , "Initialization Success");
Heltec.display->display();
//LoRa.onReceive(cbk);
LoRa.receive();
String bstr = "";
float thisway = 0;
//This is the compass code where it stops
Vector norm = compass.readNormalize();
// Calculate heading
float heading = atan2(norm.YAxis, norm.XAxis);
// Set declination angle on your location and fix heading
// You can find your declination on: http://magnetic-declination.com/
// (+) Positive or (-) for negative
// For Bytom / Poland declination angle is 4'26E (positive)
// Formula: (deg + (min / 60.0)) / (180 / M_PI);
float declinationAngle = (4.0 + (26.0 / 60.0)) / (180 / M_PI);
heading += declinationAngle;
// Correct for heading < 0deg and heading > 360deg
if (heading < 0)
heading += 2 * PI;
if (heading > 2 * PI)
heading -= 2 * PI;
float headingDegrees = heading * 180/M_PI;
//end of compass code
int packetSize = LoRa.parsePacket();
if (packetSize) { cbk(packetSize);}
getgps();
bearing = getbearing(clat, clon, tlati, tlon);
thisway = ((headingDegrees)+bearing);
bstr = String(thisway);
Heltec.display->setTextAlignment(TEXT_ALIGN_LEFT);
Serial.println (thisway);
Heltec.display->drawString(0, 15, bstr);
void getgps(){
gps.f_get_position(&flat, &flon, &age);
gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
sprintf(sz, "%02d/%02d/%02d, %02d:%02d:%02d", month, day, year, hour - 4, minute, second);
while (GPS_Serial.available())
char c = GPS_Serial.read();
//Serial.write(c); // uncomment this line if you want to see the GPS data flowing
if (gps.encode(c)) // Did a new valid sentence come in?
newData = true;
clat = (flat);
clon = (flon);
Serial.println (clat);
Serial.println (clon);
float getbearing(float lat1,float lon1,float lat2,float lon2){
float teta1 = radians(lat1);
float teta2 = radians(lat2);
float delta1 = radians(lat2-lat1);
float delta2 = radians(lon2-lon1);
//==================Heading Formula Calculation================//
float y = sin(delta2) * cos(teta2);
float x = cos(teta1)*sin(teta2) - sin(teta1)*cos(teta2)*cos(delta2);
float brng = atan2(y,x);
brng = degrees(brng);// radians to degrees
brng = ( ((int)brng + 360) % 360 );
Serial.print("Heading GPS: ");
Serial.println(brng);
return brng;
So that snippet of compass code is right out of the example and will run on its own. The compass is on I2C.
Thank you
