HMC5883l Compass HELP!!
Hello! I use hmc5883l for a project that I want to include compass. I found a nice library that states that does auto calibration, then you can put the values there and you do not have to calibrate it again. It works. The issue is when I change the height from my flat desk to totally flat floor I receive wrong values. Anyone has experience mith hmc 5883l? Also I read that MAG3110 is a little bit easier, is it true? Here is my code:
/* Author = helscream (Omer Ikram ul Haq)
Last edit date = 2014-06-22
Website: http://hobbylogs.me.pn/?p=17
Ver: 0.1 beta — Start
Ver: 0.2 beta — Debug feature included
#include <Wire.h>
#include “compass.h”
#define Task_t 10 // Task Time in milli seconds
int dt=0;
unsigned long t;
// Main code -----------------------------------------------------------------
void setup(){
// Serial.print(“Setting up I2C …\n”);
Wire.begin();
compass_x_offset = -71.31; //122.17;
compass_y_offset = 140.49; //230.08;
compass_z_offset = 112.59; //389.85;
compass_x_gainError = 1.03; //1.12;
compass_y_gainError = 1.06; //1.13;
compass_z_gainError = 0.98; //1.03;
compass_init(2);
//compass_debug = 1;
//compass_offset_calibration(3);
// Main loop
// Main loop -----------------------------------------------------------------
void loop(){
t = millis();
float load;
compass_scalled_reading();
Serial.print("x = ");
Serial.println(compass_x_scalled);
Serial.print("y = ");
Serial.println(compass_y_scalled);
Serial.print("z = ");
Serial.println(compass_z_scalled);
compass_heading();
Serial.print (“Heading angle = “);
Serial.print (bearing);
Serial.println(” Degree”);
dt = millis()-t;
load = (float)dt/(Task_t/100);
Serial.print (“Load on processor = “);
Serial.print(load);
Serial.println(”%”);
if (bearing <= 4 || bearing >= 333)
Serial.print (“North”) ;
else if (bearing <= 333 && bearing >= 290)
Serial.print (“N West”) ;
else if (bearing <= 290 && bearing >= 274)
Serial.print (“West”) ;
You must calibrate the compass every time the environment changes significantly. If it is not working correctly, it needs to be recalibrated.
