HMC5883L Compass Magnetic Declination Help
Can some one please explain if I am doing this part correctly?
// Once you have your heading, you must then add your ‘Declination Angle’, which is the ‘Error’ of the magnetic field in your location.
// Find yours here: http://www.magnetic-declination.com/
float declinationAngle = +3.70; //-0.1742;
heading += declinationAngle;
According to the Link: http://www.magnetic-declination.com/
my information is as follows:
Winnipeg Manitoba
Latitude: 49° 53' 3.8" N
Longitude: 97° 8' 49.3" W
Magnetic declination: +3° 7'
Declination is POSITIVE (EAST)
Inclination: 74° 50'
Magnetic field strength: 57079.2 nT
But I'm not sure I am using the values correctly:
Also which direction should the board be facing to point North? I keep thinking the "Y" marking on the board would indicate the facing forward.?
2016-03-25_10-30-03 by Michael Knight, on Flickr
Please do not cross post.
any solution? I have he same problem.
have a look at those links.
hope that helps.
