I programed and setup my HMC5883L sensor and when I opened the serial monitor it wasn't giving me any data, I've tried every thing I can think of and can't figure it out. Please help, Thank you
There's a sticky at the top of each forum titled "How to use this forum - please read." Item #7 of the thread shows how to post code to the forum. If you post your code, it will be easier for people to help you.
Also let us know where you found the code (include a link). A link to the hardware you're using would also be helpful. Also let us know which Arduino you're using.
This is a library example for the HMC5883 magnentometer/compass
Designed specifically to work with the Adafruit HMC5883 Breakout
http://www.adafruit.com/products/1746
*** You will also need to install the Adafruit_Sensor library! ***
These displays use I2C to communicate, 2 pins are required to interface.
Adafruit invests time and resources providing this open source code,
please support Adafruit andopen-source hardware by purchasing products
from Adafruit!
Written by Kevin Townsend for Adafruit Industries with some heading example from
Love Electronics (loveelectronics.co.uk)
This program is free software: you can redistribute it and/or modify
it under the terms of the version 3 GNU General Public License as
published by the Free Software Foundation.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_HMC5883_U.h>
/* Assign a unique ID to this sensor at the same time */
Adafruit_HMC5883_Unified mag = Adafruit_HMC5883_Unified(12345);
void displaySensorDetails(void)
sensor_t sensor;
mag.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" uT");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" uT");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" uT");
Serial.println("");
void setup(void)
Serial.println("HMC5883 Magnetometer Test"); Serial.println("");
/* Initialise the sensor */
if (!mag.begin())
/* There was a problem detecting the HMC5883 ... check your connections */
Serial.println("Ooops, no HMC5883 detected ... Check your wiring!");
while (1);
/* Display some basic information on this sensor */
displaySensorDetails();
void loop(void)
/* Get a new sensor event */
sensors_event_t event;
mag.getEvent(&event);
/* Display the results (magnetic vector values are in micro-Tesla (uT)) */
Serial.print("X: "); Serial.print(event.magnetic.x); Serial.print(" ");
Serial.print("Y: "); Serial.print(event.magnetic.y); Serial.print(" ");
Serial.print("Z: "); Serial.print(event.magnetic.z); Serial.print(" "); Serial.println("uT");
// Hold the module so that Z is pointing 'up' and you can measure the heading with x&y
// Calculate heading when the magnetometer is level, then correct for signs of axis.
float heading = atan2(event.magnetic.y, event.magnetic.x);
// Once you have your heading, you must then add your 'Declination Angle', which is the 'Error' of the magnetic field in your location.
// Find yours here: http://www.magnetic-declination.com/
// Mine is: -13* 2' W, which is ~13 Degrees, or (which we need) 0.22 radians
// If you cannot find your Declination, comment out these two lines, your compass will be slightly off.
float declinationAngle = 0.22;
heading += declinationAngle;
// Correct for when signs are reversed.
if (heading < 0)
heading += 2 * PI;
// Check for wrap due to addition of declination.
if (heading > 2 * PI)
heading -= 2 * PI;
// Convert radians to degrees for readability.
float headingDegrees = heading * 180 / M_PI;
Serial.print("Heading (degrees): "); Serial.println(headingDegrees);
Link to code: Downloads | Adafruit HMC5883L Breakout - Triple-Axis Magnetometer Compass Sensor | Adafruit Learning System
DuaneDegn:
The next thing to do would be to post some pictures of your setup.
A nice clear picture of how your board is wired.
And a clear picture of your soldering.
If you upload photos, you can insert them into your post by following these instructions.
I'm using the Arduino UNO.
I have not soldered It yet because I am working in an project with it and we are making sure all our codes and hook ups are right before soldering anything.
GabrielPierre:
That is likely contributing to your trouble getting data from it.
Oh, okay thank you
