Hmm, a library I'm writing wont link. Any thoughts
All sorted…
Will be releaseing the library soon[ish]
For others:
The AVR C++ libraries dont actually support new or delete operators implicitly. If you want to do
Foo bar = new Foo();
You actually have to write the object so it includes an associated function which mallocs or deletes the required memory.
<< Learnt that the hard way
I think you need to show us your demo sketch that’s failing to compile as well.
–Phil.
Miles, I think your library is failing to compile. The lines
int highbyte = serial.read();
and
serial.print(...);
are illegal if serial is a pointer to a NewSoftSerial object. The correct syntax in these cases is serial->read() and serial->print().
Also
      distanceMeasurementCommand = {0x22, 0x00, 0x00, 0x22};
is illegal C syntax.
Change these, delete the library.o file (if any) and try again. I like your leveraging of NewSoftSerial. Have you considering deriving UMSerial from NewSoftSerial?
Mikal
–Phil.
Hey Phil, The code is seriously simple. Nothing more than firing the constructor and requesting begin
#include <URMSerial.h>
URMSerial urm
Serial.begin(9600); // Sets the baud rate to 9600
urm.begin(2,3,9600);
//urm.requestMeasurement();
Serial.print(“Hey”);
delay(200); //Give sensor some time to start up --Added By crystal from Singapo, Thanks Crystal.
/*urm.requestMeaurement();
bool flag = true;
while(flag)
if(urm.hasReading())
Serial.println(urm.getDistance());
@mikalhart
Ah thanks a lot, I forgot to de-reference serial (my C++ is VERY rusty, .NET and Java have spoiled me!
I haddent thought of deriving from SS, that may be a good idea considering the URM has a bunch of additional functions you may want to manually request.
At the moment, I want to brush up on my C++ and then I’ll focus on the elegance and performance.
How would you suggest initalising that command, seems odd considering you can’t initalise in the header.
Oh final node: what library is “delay” in. stdlib?
Fixed
I got very confused reading the followup post until I realised you had also edited your original post.
I think the general consensus around here is to leave original posts un-touched and add the solution in a followup post. This allows people to search for the same error messages and find the solution.
Thanks for taking the time to mention your solution though.
--Phil.
P.S. I assume you didn't actually have this code working without the trailing semicolon:
URMSerial urm
Hey Follower, without the original code the post wouldn't have made sense anyway.
I thought it better to highlight the problem I had rather than leave some confusing post up :).
For the complete and correct code see here
