How do you clear the data from the UART in the Mega?
I can read bytes from the UART but I cannot figure out how to clear those bytes after I have read them. The Searl1.Flush does not do it.
// initialize both serial ports:
Serial1.begin(38400);
Serial.println("Init Complete");
bool WaitForSync()
bool ret = false;
if (Serial1.available())
byte static inByte1 = Serial1.read();
if (inByte1 == 0xB5)
Serial.println("found B5");
byte static inByte2 = Serial1.read();
if (inByte2 == 0x62)
Serial.println("found 62");
ret = true;
return ret;
if ( WaitForSync()== true)
Serial.println("found");
This chunk of code simply repeats over and over that it has found B5 and 62 but I know for sure that Its only getting one set.
Thanks.......... Jim
The value of variables defined as static persist between calls to the function. So, the first time the function is called the variables are created and values assigned to them. The second and subsequent times the variables already have values, hence your problem. Was there a reason for you to declare them as static ?
The serial library handles that for you automatically. When you read the character the serial library manages the circular interrupt driven input buffer, updating it to reflect that you have read that buffer entry.
